Boosted B16 re-birth.
Ok guys, after about 7 months of beating the **** outta my uberdata tuned boosted b16a she finally decided it was time to go, now all you can see behind me is a giant cloud of smoke. Pretty much i figure the ringlands are toast. But still managed to click off a 13.5 @ 109 pass on stock suspension and street tires. This thread will show the progress and relativly simplicity of a simple piston and rod motor. Here are the plans:
b16a .020 over bore
eagle rods
CP pistons
All OEM new oil pump/water pump
scrapping the baby t3 super 60 in favor of a 63 trim T04e
GSR cams.
Old setup:[IMG][/IMG][IMG]
[/IMG][IMG]
[/IMG]
b16a .020 over bore
eagle rods
CP pistons
GSR cams.
[/IMG][IMG]
[/IMG]
Pics arent working for me... (Edit nvrmind theyre comming up now)
You sure the motor is toast? Smoke can mean alot of things...
Anyway good luck with the build, sounds like a good plan
yeah its definatly hurt bad, for one its smoking at idle and ALOT, also it has excessive blow by coming out of the valve cover at idle as well so im pretty sure the ringlands are failing bad. It still pulls hard but i can definatly feel a loss of power, probly cuz its only running on 3 good cylinders.
got motor out and dissasembled, Unfortunatly im out of time, Going back to school now for the fall, but on a brighter note, Nasteboyii (H-T name) will be finishing the rest of the build.
Block just got sent to machine shop for the works, might be doing the cylinder head as well we shall see how deep my pocketts go. Ill get pics up soon.
SiDaddy
Mar 2, 2010 12:07 PM
tempsohc
Nov 21, 2006 10:32 AM
AnDThEnWuT
Northern California (Sales)
20
Apr 22, 2006 06:13 PM
used2baracer
Apr 19, 2005 06:08 PM
