boost spike problem.
Old Feb 19, 2006 | 02:38 PM
97grnrs's Avatar
Default boost spike problem.
i have a small turbo with my kit i am using , wastegate is supposed to be 7-8 psi , but when i drive on highway 1st and 2nd are ok but soon as i hit 3rd and start movin pretty good boost creeps past 8. so far its gone to about 11 and i saw and let off right away. ive tried another wastegate on the turbo and it does the same thing.. its internally gated, vacuum source for wastegate i ran to nipple on the turbo compressor.. i only usin an fmu for fuel management and not to mention its a stock bottom end.. im not sure how much more it would have boosted after i let off but i dont wanna find out,.. is there any way to fix this?
Old Feb 19, 2006 | 03:11 PM
The Weather Man's Avatar
are you using a boost controller? I'm assuming not - I suggest you get one(a good one). Are you using a tial wastegate?
Old Feb 20, 2006 | 05:46 AM
97grnrs's Avatar
Default Re: (TheKINGPin)
using an internal stock wastegate, i moved the line to the mani and it seems better now
V-SPEC 1
Feb 19, 2013 07:43 PM
2kTeg
Jun 12, 2005 10:34 PM
rbf351
Dec 17, 2002 06:10 AM
yorktonite
Aug 20, 2002 04:37 AM
