Boost spike + map sensor issues
Ok I got a greddy kit on my 95 sohc and the boost is spiking causing me to throw a map sensor code. How could I go about adjust the wastegate to try and lower the boost so I can keep it around 6-7 psi max so my map sensor doesn't go nuts. Also my idle is aweful. It sounds like it revs up and down pretty bad.
eg:R
Oct 23, 2005 01:54 PM
