Boost leak out of BOV
Old Jun 9, 2003 | 07:05 PM
BlackB18CTeg's Avatar
Default Boost leak out of BOV
Well, I checked EVERYTHING....
I went to a shop and they said that I need to hook up a vacuum line to the spout on the top of the BOV... Its a Max Rev BOV. I have the Wastegate hooked up to the FPR, can I hook up the BOV to the FPR too? Is this the reason why I am getting about 1/2 of the boost?
Old Jun 9, 2003 | 07:06 PM
TeStUdO's Avatar
use other spots to hook it up to, like the intake manifold, and brake booster line
Old Jun 9, 2003 | 07:07 PM
Default Re: (TeStUdO)
but do I need to hook it up? and is this reason I was leaking boost.... Where on Intake Mani do I need to hook i tup?
Old Jun 9, 2003 | 07:11 PM
TeStUdO's Avatar
if you are leaking boost, check your intercooler piping. if you didnt have your BOV hooked up to vacuum/pressure source then it wasnt opening at all
Flamenco-T's Avatar
Default Re: (BlackB18CTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackB18CTeg &raquo;</TD></TR><TR><TD CLASS="quote">but do I need to hook it up? and is this reason I was leaking boost.... Where on Intake Mani do I need to hook i tup?</TD></TR></TABLE>
anything that has a vac conencted to it, EVAP purge valve, FPR, brake booster and etc
stan
Old Jun 9, 2003 | 07:12 PM
it was opening...... I could hear it opening.....
Old Jun 10, 2003 | 09:58 AM
well here is the deal.... I took it to a shop, and I found out that the place that welded my BOV heated it up too hot and the copper siezed so the piece couldnt move. So I was running for a couple of weeks w/o BOV. Will this hurt my turbo to where I need to get a new one or rebuild my old one? From what I could tell, there was no shaftplay.
Old Jun 10, 2003 | 10:23 AM
TeStUdO's Avatar
well, no BOV will cause compressor surge which can lead to shaft play. if it wasnt very long without one you will probably be alright. just be sure to check both sides of the turbo for shaft play.
Old Jun 10, 2003 | 10:37 AM
1 Month MAX.... I mean I dont think its that bad considering no mor than 2-3 psi went to my engine at any one time
Old Jun 17, 2003 | 02:47 PM
well the shop i took it too said the following...... I need ur opinion on this
well since there was no BOV they said hte air went back through the Compressor..... They showed me hte intake pipe and there was some oil in it. They told me that I MAY have blown the bearing pack, and would need to rebuild which he said would cost about 500-600 on a T3/T4 OE........
is what he said true? Could no BOV cause that much damage in less than a month?
I mean.... most stock turbos dont have BOV and I was never boosting more than 3 psi at the time. Any feedback would be appreciated!!
Old Jun 17, 2003 | 02:51 PM
4U2NV's Avatar
Yes running and boosting w/o a BOV can and will damage the compressor wheel... It all depends on how much boost, how often, and how long bfore it will damage it beyond repair... I'd hook up the BOV, drive it, and see how it feels...
Old Jun 17, 2003 | 02:57 PM
Default Re: (4U2NV)
what would be ur guess on a t3/t4 oe running 3psi for about 1 month street driving
Old Jun 17, 2003 | 04:06 PM
disguy409's Avatar
[QUOTE= They told me that I MAY have blown the bearing pack, and would need to rebuild which he said would cost about 500-600 on a T3/T4 OE........
is what he said true?[/QUOTE]
500-600 for a rebuild? you can get a brand new turbo for that much.
Old Jun 17, 2003 | 05:35 PM
InTeGrA B18b1's Avatar
Default Re: (disguy409)
i heard max rev bov suck and leak boost. get another bov,put it on and see how it runs.
Old Jun 17, 2003 | 06:06 PM
i know...... i think he lying...
as far as the max rev BOV, it looks like its working fine now.... I took it apart and sanded it down and it fits fine now...... So I need to see how it will run.... Hopefully wel
Old Jun 18, 2003 | 10:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">well, no BOV will cause compressor surge which can lead to shaft play. if it wasnt very long without one you will probably be alright. just be sure to check both sides of the turbo for shaft play.</TD></TR></TABLE>
are u sure about that?
the guy just called me and said that because the BOV was not working all the air going the other way caused a lot of shaftplay. They said they had like a shaft play tool or something..... Is he right? I am really worried, that turbo costed so damn much......
Old Jun 18, 2003 | 10:29 AM
alpha's Avatar
There are a couple people here with MaxRev blowoff valves. They have not had a problem with them but they are all running 8lbs-11lbs of boost. $500.00 for a rebuild? What shop is this again? I still don't think your turbo needs a rebuild due to the fact you were not running that much boost. If you DO NEED a rebuild talk to Cheap Turbos and Precision. Precision will warranty their work for 12 months or 12,000 miles. $500.00 is a new T3/T04 turbo.
Old Jun 18, 2003 | 11:29 AM
Default Re: (0x64)
i know, i think the poeple were BS'ing me......
the even told me to get a bigger turbo !?!?! I was the turbo is already HUGE... t3/t4 oe is NOT a small turbo....
he told me I should sell the old turbo and get a bigger one.
1 month at 3psi w/o BOV I dont think would require a rebuild... But I could be wrong... any other comments? THANKS!!
Old Jun 18, 2003 | 11:35 AM
mike1114's Avatar
I would say just drive it a bit and see if it feels like it should. Make sure your hitting the proper set boost level, make sure your not puffing out tons of smoke anywhere (or oil) and you should be good.
I think your "SHOP" just wants the cash for doing a turbo rebuild for you. You can have it done much cheaper , $500 is a brand new turbo, not rebuild.
Old Jun 18, 2003 | 12:24 PM
alpha's Avatar
We nothing about your power goals but I know people making 419whp and 335whp here with a T3/T04E. They probably wanted you to buy the turbo from them? Keep us updated.
GReddy_Civic
Aug 13, 2008 08:38 AM
Chris1091
Jun 2, 2003 10:38 PM
niedejb
Jun 7, 2002 06:26 PM
Smoothy
Nov 14, 2001 08:48 PM
GruvyTune
Oct 22, 2001 06:16 PM
