Boost guage
Old Mar 5, 2003 | 05:03 PM
BubRub's Avatar
Default Boost guage
I was wondering how u guys connected the wires for the light so they would turn on whenever u turn ur headlights on? Also how did u connect the tiny vinyl vacuumn line to the intake manifold? Which hole did u use for an integra? I have an integra and the autometer phantom boost guage. thanks
Old Mar 5, 2003 | 05:06 PM
Daniel's Avatar
Default Re: Boost guage (BubRub)
for the light, i tapped into the dimmer switch. works great.
don't pay attention to autometer's instructions. i used part of their clear vacuum line, inserted one end into the boost gauge and inserted this little hose connector into the other end. then, i used "regular" vacuum hose that goes from the hose connector, through the firewall, and is connected to an HKS "T" fitting that is spliced into my BOV vacuum hose.
Old Mar 5, 2003 | 05:26 PM
blu_si's Avatar
If you own a honda/acura look for a black/red wire either at the back of your dimmer switch or in a bundle of wiring coming down from your steering column behind your underdash panel.
Old Mar 5, 2003 | 05:33 PM
T3's Avatar
T3
Default Re: Boost guage (blu_si)
http://www.seansa4page.com/mya4s/995...oostgauge.html
http://www.carreview.com/projectecli...tgaugecrx.aspx
http://www.seansa4page.com/mya4s/97/boost/boost.html
Old Mar 5, 2003 | 05:52 PM
BubRub's Avatar
Default Re: Boost guage (T3)
theres 2 wires from the light bulb, do i tap both into the red/black wire or one to the red/black and one ground on the chassis? thanks
Old Mar 5, 2003 | 06:02 PM
Daniel's Avatar
one is for the red/black and the other is for ground. For ground, i used an existing ground wire. i dunno if it's safe or not, but so far no problems.
Old Mar 5, 2003 | 06:07 PM
BubRub's Avatar
Default Re: Boost guage (Daniel)
thank you guys for your help.
boosted.CRX
Dec 12, 2006 06:13 PM
blackccoupe
May 18, 2004 07:26 PM
SSR'd
Jan 26, 2004 08:34 PM
ATS*Mark
Aug 20, 2003 06:16 PM
LOwrestling2001
May 20, 2002 12:00 AM
