Boost cut engaging
Old Mar 7, 2023 | 04:57 AM
EGJake30's Avatar
Default Boost cut engaging
Hello all
So I just rebuilt my GSR transmission and gave it some face-plated gears. The car sat from middle of September until this week.
I got about 100 miles on her so I decided to try to do a nice easy pull in 5th.
Turbo starts to spool hits about 3lbs and boost cut is kicking it. I was pushing over 20lbs before I did the transmission. (Which is going great by the way!)
I haven’t plugged in the s300 yet. Before I do tonight I was wondering if anyone has any idea as to why this would be happening if I never changed anything with my ECU?
Old Mar 7, 2023 | 08:05 AM
Pepe14's Avatar
5 Year Member
Loved
Community Favorite
Default Re: Boost cut engaging
Check your spark plugs.
Old Mar 7, 2023 | 09:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
If you weren't using the S300 ECU before when you made 20psi, what ECU did you use ? Is it different than what you are using now ?
Old Mar 8, 2023 | 02:15 AM
EGJake30's Avatar
Im using the same ECU haven’t done anything.
thinking I could have a bad sensor somewhere done think it’s a tune issue
Old Mar 8, 2023 | 04:58 AM
Chance EG's Avatar
I was thinking this too, I think he meant he just hadn't plugged his computer into the S300 yet to view logs.
Old Mar 8, 2023 | 05:05 AM
EGJake30's Avatar
Unfortunately I don’t have a cord to run to my PC. I have v3 though.
I should be able to download the software on my PC then link with Bluetooth correct?
Old Mar 8, 2023 | 05:32 AM
Chance EG's Avatar
I'm actually not sure if you can use the bluetooth to download the log files, most uses of bluetooth with the S300 I've seen are people using them to display gauges/info.
Edit: May be worth investing in a cheap $200- laptop just so you can use it for things like this. Look for used business laptops on eBay - Thinkpads, HP Elitebooks, Dell Latitude. Some companies throw out several dozens of those every month, they've gotta end up on the market somewhere.
Old Mar 8, 2023 | 12:15 PM
Ryanthegreat1's Avatar
This is fantastic advice. Amazon lists them as renewed. They come preloaded with legit licensed windows 10 or 11. I happen to point a lot of people this direction as well.
Old Mar 8, 2023 | 12:43 PM
DaX's Avatar
DaX
Loved
Community Favorite
You need a "USB printer cable" or a USB A male to USB B male cable. Search on Amazon and you can have one cheap in just a couple of days. I've got a 15 footer...they may even make longer ones than that, if you have to run it to your PC.
Old Mar 8, 2023 | 04:58 PM
USB without a repeater is limited to 15'. You can sometimes get lucky and run longer without but the spec is 15'.
Old Mar 9, 2023 | 03:21 AM
EGJake30's Avatar
Turned out that my ECT was plugged into the wrong spot. Feeling dumb today but hey glad it was so simple.
h2b_sedan
Engine Management and Tuning
Nov 29, 2009 05:45 PM
espanol
Mar 13, 2003 09:23 AM
incognitoracerr
Jan 10, 2003 05:42 PM
95LSVTEC
Oct 4, 2001 08:10 PM
