boost creep prob.....any suggestions???
Old Mar 20, 2004 | 10:15 AM
B1Boosted's Avatar
From: from a lil town called none ya gatdamn business, usa
Default boost creep prob.....any suggestions???
i have an lsvtec turbo b16 head with tial waste gate and w/ a 6psi spring in the WG and a profec b boost controller.....before i did the head swap i had no boost creep at all....now it is boost creepin to like 15psi with the boost controller off which should be at wastegate boost (6psi)....even when i set the boost controller on low boost and turn it all the way down it still boosts 15psi.... so i rerouted the vacum lines to bypass the profec b as if it was not there and it still creeps 10psi on wastegate boost w/ a 6psi spring.... help
Old Mar 20, 2004 | 11:26 AM
MaxSterling's Avatar
Default Re: boost creep prob.....any suggestions??? (B1Boosted)
get better wastgate or small diameter exhaust.
Old Mar 20, 2004 | 11:48 AM
Sohc Driver's Avatar
Default Re: boost creep prob.....any suggestions??? (MaxSterling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxSterling &raquo;</TD></TR><TR><TD CLASS="quote">get better wastgate or small diameter exhaust.</TD></TR></TABLE>
That Tial gate is fine...there has to be a reason...have you checked all of your vacuum lines...are they all hooked up correctly? have you examined the wastegate itself?
Khoi
Old Mar 21, 2004 | 09:40 PM
Robzible's Avatar
yeah , consider gettin rid of that junky tial .....................not , thats one of the best wastegates on the market , double check the vaccum lines
Old Mar 21, 2004 | 10:53 PM
Mase's Avatar
what exhaust manifold are you using?
Old Mar 21, 2004 | 11:12 PM
Robzible's Avatar
Default Re: boost creep prob.....any suggestions??? (Mase)
hes using a ss chrome , equal length tubular , the wierd thing is the car didnt have boost creep until he installed the vtec head , i think its just a vaccum line problem , but lets us know what you think , thanks
Old Mar 21, 2004 | 11:14 PM
nigel's Avatar
yeha what mase said.
if you have a 3 inch dp it can cause you to creep, if you have open dp it can cause you to creep, and if your vac lines go all the way to the intake mani or to the throttlebody area it can cause you to creep.
Old Mar 21, 2004 | 11:15 PM
Robzible's Avatar
Default Re: (nigel)
well he doesnt have a 3in dp , or an open dp , so its obviously the one of the other situations , thanks
Old Mar 23, 2004 | 12:27 PM
B1Boosted's Avatar
Default Re: (Robzible)
thanks rob.... ok heres the deal....i checked all vacum lines and completely bypassed the profec b and i swapped out WG to one of my friends delta gates and it stopped goin to 15psi...now it still creeps to 10psi which is where i want it but it would still be nice to know why its doing this thanks for all feedback
Old Mar 24, 2004 | 10:40 PM
B1Boosted's Avatar
Default Re: (B1Boosted)
ok **** everything ive decided that i like alot of boost and i dont care if it scaters but if you have anymore sug. let me know.....until then drivin like its stolen.. thanks
Old Mar 25, 2004 | 05:46 PM
B1Boosted's Avatar
another thing is....i have a dump tube that is ran down and out my driverside bumper......i am about to take it off and see if it fixes anything.....any more sug??
Old Mar 25, 2004 | 06:46 PM
B1Boosted's Avatar
after removing the dump long *** dump tube the car no longer boost creeps...now im goin to hook the profec b up again and see if anything changes...
Old Mar 25, 2004 | 06:59 PM
dunkd's Avatar
wow, exactly how long was the dump? any pics?
Old Mar 25, 2004 | 07:39 PM
B1Boosted's Avatar
Default Re: (dunkd)
i do have pics but not on here right now i will post some but its about 2 1/2 to 3 ft long....
Old Apr 5, 2004 | 11:26 PM
B1Boosted's Avatar
actually it still creeps 10psi which is no big deal because thats ideal boost for low boost....no pics of dump tube right now bc camera is fucked up...but i will see what i can do about pics thanks
Old Apr 7, 2004 | 08:56 PM
B1Boosted's Avatar
nychonda
Jul 1, 2009 04:37 PM
turbo95eg6
Jun 12, 2005 12:15 PM
1RS2NV
Mar 15, 2004 03:18 AM
Snafu-Si
Mar 5, 2002 02:07 AM
Cyrio
Dec 4, 2001 07:00 PM
