Boost creep issue
Old Mar 17, 2011 | 09:07 PM
rico892002's Avatar
Default Boost creep issue
hey guys i have a built gsr turbo with a stock gsr head and blox intake manifold...well i jus got my car tuned on 15psi (wastegate spring) and my car creeps on 18-20psi in 4th full traction...im tryna find out how to fix this problem...
my turbo set up is
t70 turbo 82ar
ram horn manifold
38mm tial wastegate(15psi spring)
thanks for the help
Old Mar 17, 2011 | 09:33 PM
dk=gsr's Avatar
Default Re: Boost creep issue
get 44mm wastegate or bigger.
but 44 should be fine.
Old Mar 17, 2011 | 09:53 PM
98integralsB18's Avatar
yeah, get a 44m wastegate. Or the tune is a little off, I have read somewhere where a kids timing was a little off I do not really know how but thats what he said.
Old Mar 17, 2011 | 10:17 PM
rico892002's Avatar
could i just order this...http://cgi.ebay.com/ebaymotors/Tial-...item5636737140
and then buy a 44mm wastegate so i dont have to get a new manifold?
Old Mar 18, 2011 | 02:41 AM
SD_Lurker's Avatar
HT White Ops
Yes but it defeats the purpose of having a 44 in the first place.. A bigger opening allowing more air to bleed off. I suppose you could open up the hole a bit to match the gate..
Old Mar 18, 2011 | 05:07 AM
CDecker0218's Avatar
You need a 44mm.
Old Mar 18, 2011 | 06:51 AM
QUICK8CIVIC's Avatar
check your boost signal hoses for kinks and use the two boost ports with a boost controller before upgrading gates.
Old Mar 18, 2011 | 07:25 AM
wantboost's Avatar
Who is Mr Robot?
Pictures of setup? Sounds eBay to me.
Old Mar 18, 2011 | 09:38 AM
rico892002's Avatar
my lines are kink free...i really dont understand how a boost controller will fix the problem...i have a hallman boost controller lay around...and i dont really have ebay parts everything is name brand on my car...i mean my manifold is a obx manifold but it does work.it made 440whp and 300tq on 15psi.
he is a bad picture of the set when i first put the motor in
Old Mar 18, 2011 | 11:11 AM
Bizzle5OH3's Avatar
I have almost an identical set up ( just not an OBX manifold ) but ramhorn style. My tial 38mm wastegate has a 12LB spring but on the dyno it kept wantin to go to 18 so I just set boost cut out at 17lbs and run 16PSI now. Tuner said get a bigger wastegate and itll fix the problem but it wasnt a must cuz the tune was still perfect at 16PSI and my HP numbers were fine for the motor.
Old Mar 18, 2011 | 03:44 PM
cruizinmax's Avatar
I would guess your creeping due to the fact the wastegate appears to have been cut and welded back on. Get a better manifold would be my solution.
Old Mar 18, 2011 | 06:11 PM
AutoSensei's Avatar
The angle of the wastegate is not great and that's a very large turbo to be regulating with a 38mm. If I were in your shoes I would do the following:
1. Take the manifold to a machine shop to have the wastegate runner adjusted angling it towards the ground so the path is in line with the natural flow of the exhaust gases.
2. Get a larger gate anyway. With that turbo you want to be as precise as possible since it seems likely you will be running low boost most of the time.
Old Mar 18, 2011 | 11:38 PM
DelSolMarine's Avatar
do not get the adapter to go from a 2 bolt 38mm flange to a 44mm vband for the 44mm tial wastegate... i have done it and it didnt not work...
you need to cut the 38mm flange off and replace with a 44mm vband flange to run the bigger wastegate... the inlet on the wastegate outlet has some horrible welds that should be redone and while your at you should someone ELSE do the welding...
DelSolMarine
Apr 17, 2022 10:21 AM
Boosted00
Jan 19, 2018 01:51 PM
Walterronny
Feb 10, 2015 12:05 AM
LilCivic04
Jul 12, 2005 10:25 PM
GruvyTune
Apr 23, 2002 07:08 AM
