Boost Creep Advice
I did some research on here and google about boost creep issues but i want to get some advice about my setup
Setup: Go-autoworks mini ram manifold
Comp t3/t4 turbo billet wheel
3 inch downpipe, 2.5" cat, 3 inch cat back
2.5 inch ic piping
new but old school turbonetics delta gate wastegate
Grimmspeed MBC
Built B18C1 with skunk 2 tuner stage 2 cams
I was street tuning it last night and on the boost controllers lowest setting which is turned all the way out, grimmspeed says that is stock wastegate setting or 7psi
From a dig or any kind of rolling start, the boost pressure will stay at 7 psi until right around 5,000 rpm and then start climbing, after vtec it gets higher and hondata will reach boost cut
so the questions come to mind?
1.) are the mbc vaccum lines close enough to the wastegate? the mbc is mounted on the driver frame rail
2.) is this wastegate efficent enough? I read stories about the turbonetics delta gate having creep issues last night
3.) is my boost source incorrect? I do have the turbo tapped on the housing for the boost source, should i use the manifold as a source instead?
any advice would be appreciated
2.5 inch ic piping
Grimmspeed MBC
If you get no creep without the MBC then the problem is clearly related to the MBC. How do you have it plumbed? And how much boost creep are we talking about?
sry sry.. i dont have a pic with me right now.. but the mbc sits on the frame rail on the driver side. The bottom hose of the mbc goes to the turbo tap and the side hose of the mbc goes to the side of the wastegate. I have an edelbrock manifold with front mount intercooler tr8 from treadstone and 2.5 inch piping from turbo to tbody.
Ah... The reference to the compressor cover might be a bit too strong.. that's happened before. Move the hose that's going to the compressor cover to another reference point like the intake manifold as its vacuum reference instead.
It could actually be BOTH the reference point and the gate as the problem, as the valve may have experienced different fuels and because of its makeup (and age) may not be opening when it should.
1) Change the reference point to the Intake manifold.... Test on a drive, see what it does..
2) If no change, then make sure that adjustment nut on top of the Deltagate is down all the way. Test on a drive again, see what it does.
3) If STILL no change, look at the valve for a change in color in the wastegate valve stem itself. if it looks a bit cooper-ish in color, that means different fuels have been used (Race gas, Alcohol, etc from the previous owners) and may have affected the valve itself on a metallurgical level. If that's the case, throw it out, and get a TiAL or turbosmart in a 2 bolt flange. (Yes, TiAL still makes 2-bolts)
4) Being Leary won't solve the problem... Gotta make some moves to solve issues. Hop to it..
Who is Mr Robot?
The mbc is the problem 9 times out of 10. It's basic, unintelligent boost control that can't control creep
Remove it and run a line from the compressor housing to your wastegate and see if it goes away. I'm betting it will. Also that 2.5" cat on a 3" system could cause some issues as well
Its simply a boost reference point. the controller itself is fine. I've bet my life on the Grimmspeed before. Has never failed yet.
Who is Mr Robot?
I know about hallman and gfb. I have a few gfb parts laying around
The problem is mbcs aren't "intelligent" boost control. You can set it for a certain psi but it cannot control creep and keep boost at the target level if creep occurs
Yes, but that's what makes it so nice and simple. Change your boost vacuum reference point and problem is solved. No electrical solenoids or other nonsense to worry about..A case where ignorance is bliss.. *sigh* ahhh the good ole days.
9 times out of 10 a MBC causes boost creep problems? I've never seen someone install a manual controller and suddenly have boost creep issues. If you want to run one single boost level then you don't need "intelligent" boost control, MBC will work fine.
Who is Mr Robot?
The problem is a lot of people using mbcs use the compressor housing as the pressure reference. There's a lot of pulsation and fluctuations in the compressor volute which causes issues not only with mbcs but with ebcs as well.
All I'm saying (like you) is that if you had no creep issues running off the wg spring then install an mbc and then at some point have creep (mostly weather related, i.e. very cold temps) then the mbc has knoe way of "knowing" what its targrt boost level is and cannot lower boost should it "creep"
Ebcs, especially ones run by ecus and standalones take a lot of data into account to control target boodt pressure and the boost pressure ramp up time to targrt boost. Things like barometric pressure, iats, engine load, tps, rpm and some even measure humidity. This leads to overly precise control of the target pressure and should pressure levels exceed target boost then the ecu knows what measures to take to try and lower. Like modulating the solenoid cycles, modulating solenoid frequency, and in some cases closing the solenoid all together, like if the boost pressure reaches the boost cut value
Yeah, but if that was the case where it worked in a perfect world, you wouldn't be seeing all these "boost creep" threads using a MAC solenoid and Hondata S300 like we have been the last few months.
MBCs work for their particular purpose. Its like what Mr. Scott on Star Trek said once: "The more you overwork the plumbing, the easier it is to stop-up the drain.
Who is Mr Robot?
That's simple. The boost tables were tuned at warmer temperatures. Now that it's cooling off the tables are off. We'll see more threads like this pop up as it gets even colder
Kinda like when summer is in full swing overheating threads pop up like stds. I can always tell what time of yesr it is by the threads people post on HT lol
Who is Mr Robot?
Yea and they don't know why all of the sudden they have overboosting issues
It's even worse with mbcs as the boost will just continue to climb until eventually you hit boost cut(if you have one setup, which everyone should) (just like the OP is describing)
To the OP, the compressor housing is a bad spot for a boost signal. There's a lot of turbulence in the compressor volute as it compresses the air, which causes varying pressure waves and pressure levels. Move the signal to the intake manifold after the throttle body, you'll notice a much smoother boost curve and the mbc will better control boost because it's not getting a random pressure signal like it does at the compressor housing.
Another thing is does your mbc have a stainless steel or ceramic ball? Sometimes swapping to a ceramic ball will help with creep as the reduced weight of the ball allows it to respond much quicker to fluctuations in boost pressure. Sometimes it will even eliminate creep but that varies from setup to setup and with things like elevation, temperature, and humidity.
Who is Mr Robot?
I know. I might suggest the OP pull the mbc apart and clean all of the components, if any oil or debris gets inside the controller body it could block off the bleed port and cause issues with the ball travelling inside the unit. Leading to a failure of the units ability to accurately regulate boost pressure. All of which could be causing some of his issues
Especially since he had the pressure source on the compressor housing, it could of ingested oil, debris, etc. Especially if a proper filter wasn't being used
