Which boost controller, Turbo XS?
I'm looking at getting either a turbo xs standard boost controller or the high performance one. What is the big difference between the two, is the high performance one less likely to spike?
before u purchase that, look into the Turbosmart Boost Tee. The TurboXS MBC is adjusted w/ an allen key. And when that thing is in the engine bay, it can be difficult. The Turbosmart Boost Tee is adjusted by a twist ****. The best thing is that the Turbosmart Boost Tee clicks when you turn the ****. This helps you tune the car and it prevents the **** from backing itself out while in the engine bay.
There is a lock out allen key on the boost tee, but you don't have to use it.
1A4
Feb 2, 2007 12:01 PM
