bolts for revhard manifolds
Old Oct 21, 2003 | 11:29 AM
bigwig's Avatar
Default bolts for revhard manifolds
i searched with no results...
what bolts do you use to connect a T3/T04e to a revhard b-series manifold?
thanks
Old Oct 21, 2003 | 11:55 AM
TRE_'s Avatar
This was posted by Flamenco-T a while back I think... hopefully its somewhat helpful:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> Manifold to Turbo bolt size
Drag, Rev-Hard, Inline Pro - 10mm x 1.25 [30mm] ( length of the bolt)
Max-Rev - 3/8 x 24 fine thread
Turbo to Downpipe flange bolt size
T3 only 8mm x 1.25mm [20mm]
Oil return Flange bolt size
8mm x 1.25 [20mm]
35m Wastegate to manifold bolt size
8mm x 1.25 [20mm]
Stock Map Sensor Bolt
4mm x 0.7mm [15mm]
O2 sensor bung or bolt to plug it up
18mm x 1.50
Oil Return Parts list
Oil Drain Flange 1/2"
1/2" to -10AN adapter 45 degrees adapter
45 deg -10AN swivel seal hose end
Straight -10AN Swivel seal hose end
1' of -10AN 200 series hose.
-10 steel weld on bung
**<FONT COLOR="red"> I only sells and a distributor for all Goodridge Fittings and Hoses, <U>Goodridge</U> </FONT>
Oil feed line part list
1- male 1/8" BSPT to female 1/8" NPT adapter (aluminum)
1- 1/8" NPT Brass Tee adapter with one male out and two females.
1- 3.5' of -3AN lines with hose ends attach
1- straight 1/8" NPT to -3AN adapter
1- 90 deg 1/8" NPT to -3AN adapter
Top of stock fuel filter bolt size if you wanna run a SS lines to filter
12mm x 1.25
Greddy EGT probe bung thread size
1/8" NPT with 27 thread pitch
I'll add more as I remember...or if you have a suggestion, post it, and I'll add it to my list
stan
Modified by Flamenco-T at 4:10 PM 9/24/2003</TD></TR></TABLE>
Old Oct 21, 2003 | 11:58 AM
TurboDANDEE's Avatar
Default Re: bolts for revhard manifolds (bigwig)
i used an OEM Honda 14mm bolts w/lock washers... its holding up for almost 2 years now
Old Oct 21, 2003 | 12:14 PM
bigwig's Avatar
thanks a lot, thats really helpful!
done
Welding / Fabrication
Feb 21, 2009 10:14 AM
BoOsTiN Dc2
Mar 20, 2005 04:07 AM
phiberoptik
Jul 29, 2003 04:21 AM
bretx0r
Dec 27, 2002 12:25 PM
