Blue smoke
Old Mar 4, 2003 | 12:04 PM
underpressure02's Avatar
Default Blue smoke
K here goes another off the wall question. When i am driving in 5th gear between 3000 and 4000 rpms and get off the gas and back on I see a puff of blue smoke come out. But if get off the gas and do not get back on for about 15 seconds nothing comes out. But if I get on the gas hard or do the same thing above 3-4000 it does not happen. Anyone have a similiar problem? Thanks
Old Mar 4, 2003 | 12:53 PM
DBallz's Avatar
Default Re: Blue smoke (underpressure02)
Sounds like your burning oil. You might be getting some blow-by. What is your setup?
Old Mar 4, 2003 | 01:09 PM
Default Re: Blue smoke (DBallz)
Right now I am running a stock ls motor with a drag gen III turbo kit. 550 cc injectors, aem ems. This is only temp till i rebuild my blown motor. Think it is anything to worry about?
Old Mar 4, 2003 | 01:29 PM
sgT's Avatar
sgT
when you get off the gas, the engine shuts down and there is no load.
Old Mar 5, 2003 | 04:49 AM
Default Re: Blue smoke (sgT)
So why would this make it smoke? And only smoke in 5th gear? When you say the engine shuts down? The engine is still running I agree with you on the no load part by why still the oil?
Old Mar 5, 2003 | 04:53 AM
MiraiZ's Avatar
no blowby is more intense than that...I would guess valve guides and or seals going south
Lucky-13
Jan 31, 2007 05:21 PM
gsron
12
Aug 14, 2006 04:59 PM
integ u
11
May 20, 2004 08:13 PM
Layziebtnh055
Apr 18, 2004 11:45 AM
92HB_HB
May 5, 2002 06:24 PM
