Blox IM?
Old Jan 24, 2007 | 01:19 PM
invisible's Avatar
Default Blox IM?
anyone using this on their turbo set up? worth it to change out the stock gsr with this? only plan to make about 300-350.
Old Jan 24, 2007 | 01:57 PM
delslo93's Avatar
Default Re: Blox IM? (.Huey)
Yes they're def. nice for the money. A lot better than a stock GSR IM. Its basically a ported out ITR manifold.
Old Jan 24, 2007 | 02:16 PM
chinners10's Avatar
Default Re: Blox IM? (delslo93)
i got one.. no complaints.. its no skunk2 but it does the job
Old Jan 24, 2007 | 02:19 PM
95dc2teg's Avatar
Default Re: Blox IM? (cxhatch02)
i thought there wasnt a big difference between skunk2 and blox intake manifolds?
Old Jan 24, 2007 | 02:25 PM
sc4dr's Avatar
Default Re: Blox IM? (95dc2teg)
My blox works really well. 450 whp@ 16 psi.(pump gas)
Old Jan 24, 2007 | 02:31 PM
Amped's Avatar
Default Re: Blox IM? (sc4dr)
i have one for sale, ill give it to you for 130$ shipped. I am putting a jrsc on instead. Its brand new. U interested?
Definatly a good investment to a blown engine.
Old Jan 24, 2007 | 05:56 PM
invisible's Avatar
Default Re: Blox IM? (Amped)
i'll probably pick one up then
Old Jan 25, 2007 | 07:54 PM
invisible's Avatar
anyone else
Old Jan 25, 2007 | 09:53 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
I got one... its got a better mid range power than pretty much all others so its perfect for street/strip. In your case its definately better than a stock gsr dual stage pos.
Old Jan 25, 2007 | 09:57 PM
invisible's Avatar
Default Re: Blox IM? (ForceFed_Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">I got one... its got a better mid range power than pretty much all others so its perfect for street/strip. In your case its definately better than a stock gsr dual stage pos.</TD></TR></TABLE>
so it would be fine to run on stock gsr for awhile? motors out so just trying to knock out all i can now.
Old Jan 25, 2007 | 10:19 PM
If you have the motor out i would suggest just doing it now, it would be a lot easier and is a good investment. Well worth the money!!!
Old Jan 25, 2007 | 10:25 PM
invisible's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">If you have the motor out i would suggest just doing it now, it would be a lot easier and is a good investment. Well worth the money!!!</TD></TR></TABLE>
i read that i might loose low end power using it on a stock gsr?
Old Jan 25, 2007 | 10:35 PM
You lose torque because the runners on the IM are shorter than stock... theyre short so that at high rpm's air/fuel can fill the cylinders as fast as possible. In this case the blox mani has a pretty good mid to high range power gain and is worth the investment.
I assumed you were running a boosted application being in the FI section, for a street/strip boosted application like i mentioned its perfect.
Old Jan 25, 2007 | 10:39 PM
invisible's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">You lose torque because the runners on the IM are shorter than stock... theyre short so that at high rpm's air/fuel can fill the cylinders as fast as possible. In this case the blox mani has a pretty good mid to high range power gain and is worth the investment.
I assumed you were running a boosted application being in the FI section, for a street/strip boosted application like i mentioned its perfect.</TD></TR></TABLE>
It will be boosted, like i said just want to knock out anything I can
Old Jan 25, 2007 | 10:40 PM
iBrandon's Avatar
i duno how they are designed now...but when they first came out...i had an ls one installed onto a buddys car...he was boosting and the coolant nozzle broke off...But overall people seem to have good success with them!
Old Jan 25, 2007 | 11:10 PM
da_dude's Avatar
I'm thinking of getting one too.
Old Jan 26, 2007 | 05:16 AM
Teg6's Avatar
Default Re: (turb20_vtec)
Go for it. I have a skunk2 and it made a big difference of the stock IM. Nice mid range gains.
tomlinson619
Apr 14, 2006 04:26 PM
GSRVTEC1
Feb 17, 2006 04:19 PM
THE94GSR
May 13, 2004 08:04 AM
92HB_HB
Apr 8, 2004 04:07 AM
B18C-EJ1
Jan 20, 2002 01:16 PM
