blown seal or bad return line??
Old Jun 30, 2004 | 10:12 AM
Krayzielix's Avatar
Default blown seal or bad return line??
when i start it up..oil jus pours out the exhuast side of the turbo..
Old Jun 30, 2004 | 01:04 PM
Redwidow's Avatar
Default Re: blown seal or bad return line?? (k12ayz1e)
What size oil feed line are you using...you should be using a 3AN...solved my problem.
Old Jun 30, 2004 | 01:08 PM
hybrid515's Avatar
Default Re: blown seal or bad return line?? (Redwidow)
im not sure it came with my turbo
Old Jun 30, 2004 | 07:22 PM
solowerks's Avatar
Default Re: blown seal or bad return line?? (hybrid515)
Bigger oil return the better. I use a 5/8" and it works perfect. I had a bad problem at first with oil leaking out of my turbo at the exhaust side. I made sure my line was pretty much straight down, and un kinked....my problem was solved. Also what size feed line are you using? If it is too big ditch itbecause it will supply too much oil pressure. I use a -4an because I bought it and it works, but would suggest a -3an... Trouble shoot ALL the easy solutions first before jumping to major ones like blown turbo seals...ect
Old Jul 7, 2004 | 12:25 PM
Krayzielix's Avatar
Default Re: blown seal or bad return line?? (solowerks)
anyone..i just changed my feed line and return line..and oil still comes out
Old Jul 7, 2004 | 12:53 PM
djfob's Avatar
how much oil pressure you runnin to the turbo?
Old Jul 7, 2004 | 01:19 PM
Krayzielix's Avatar
Default Re: blown seal or bad return line?? (djfob)
im not sure i dont have a guage for it
Old Jul 7, 2004 | 09:56 PM
Krayzielix's Avatar
how can you tell if your seal is blown??
Old Jul 7, 2004 | 10:21 PM
Cramerox's Avatar
you can tell sometimes because tehre is oil in the charger pipe and intercooler....that or you could have filled with to much oil.
Old Jul 7, 2004 | 11:12 PM
Krayzielix's Avatar
Default Re: blown seal or bad return line?? (Cramerox)
theres no oil in the charge pipe or ic its all coming from the exhaust side
Old Jul 8, 2004 | 12:16 PM
Krayzielix's Avatar
anyone kno?
Old Jul 8, 2004 | 02:21 PM
solowerks's Avatar
like i said before
Old Jul 8, 2004 | 04:18 PM
LoSt is BlaCk's Avatar
Default Re: (solowerks)
is your motor over filled with oil? you can do a simple rebuild on the turbo yourself if you wanna save money...
CivicDude2k4
Sep 5, 2006 08:24 PM
MotorMouth
Mar 20, 2006 07:12 PM
harryg
Sep 10, 2003 07:21 PM
Blown90hatcH
Dec 26, 2001 11:26 PM
