Blown head gasket- Should I lower the compression when I replace it?
Old Aug 17, 2005 | 04:03 AM
b18psi's Avatar
Default Blown head gasket- Should I lower the compression when I replace it?
I have a b18c1 at 10 psi and hondata with 300whp. I blew my headgasket yesterday and will be replacing it myself in a few weeks. I am going to get arp head studs. What I want to know is should I get the OEM or Cometic head gasket? And should I buy a thicker hg to lower my compression? Will I need to retune my ECU after that change? Thanks
Old Aug 17, 2005 | 04:06 AM
Nidius's Avatar
Default Re: Blown head gasket- Should I lower the compression when I replace it? (b18psi)
Leave it stock, and find a better tuner.
Old Aug 17, 2005 | 04:17 AM
VisualAutoMotoring's Avatar
Default Re: Blown head gasket- Should I lower the compression when I replace it? (NidStyles)
Either or doesnt hurt to do. Make sure when you head gasket blew that it didnt overheat or warp your head. But im sure it didnt. Find out your cause for the blown gasket cause 300whp on GSR shouldnt be happening.
*shameless plug -- we're having sales on Golden Eagle, Cometic, ARP combos'
Old Aug 17, 2005 | 04:19 AM
b18psi's Avatar
I have been driving it at 7 psi with a fmu for a year and then another year and 2 months at 10psi with Hondata. I just figured it was getting worn out????
Old Aug 17, 2005 | 04:21 AM
Default Re: (b18psi)
Head gaskets dont really "wear out"
Either temps got hot or your head lifted
Plus depending where your from and right now other than Alaska, its pretty hot around.
Old Aug 17, 2005 | 04:32 AM
b18psi's Avatar
It has never overheated but the weather has been close to 100 in the past two months. By worn out I meant that the head bolts are stretching.
Old Aug 17, 2005 | 04:40 AM
b18psi's Avatar
About my initial question, should I replace my head gasket with a thicker one to lower compression or is that not nessecary?
Old Aug 17, 2005 | 05:33 AM
wantboost's Avatar
Who is Mr Robot?
just buy an oem gasket and get some arp's
Old Aug 17, 2005 | 05:42 AM
tilt's Avatar
IMO, not necessary. You can always run a conservative tune.
My headgasket went cuz I overheated the engine at the track. Corrected the problem with a better radiator. Replaced my gasket with oem, added some arp studs and it's been runnin' strong since.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18psi &raquo;</TD></TR><TR><TD CLASS="quote">About my initial question, should I replace my head gasket with a
thicker one to lower compression or is that not nessecary?</TD></TR></TABLE>
Old Aug 17, 2005 | 05:58 AM
b18psi's Avatar
Does everyone agrre that OEM hg and stock compression is the way to go?
Old Aug 17, 2005 | 06:05 AM
.nate's Avatar
No reason to lower the compression if the motor is running ok with no detonation, and if you have no plans to turn up the boost. OEM
Old Aug 17, 2005 | 06:29 AM
tuoniz's Avatar
agreed that arps are in order.
Old Aug 17, 2005 | 08:08 AM
b18psi's Avatar
OK, I will be keeping the factory 10:1 c/r but which brand should I use, the OEM or Cometic?
Old Aug 17, 2005 | 08:21 AM
wantboost's Avatar
Who is Mr Robot?
OEM, cometic gaskets are overpriced and suck ***
Old Aug 17, 2005 | 08:35 AM
tuoniz's Avatar
I just ordered a cosmetic gasket i hope my withstands the 20+ boost im throwing at it
Old Aug 17, 2005 | 11:23 AM
b18psi's Avatar
Anybody else have a preference?
Old Aug 17, 2005 | 11:30 AM
wantboost's Avatar
Who is Mr Robot?
dude. oem gasket... arp headstuds and be done with it
Old Aug 17, 2005 | 12:06 PM
Thurman Merman's Avatar
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">just buy an oem gasket and get some arp's</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">OEM, cometic gaskets are overpriced and suck ***</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">dude. oem gasket... arp headstuds and be done with it</TD></TR></TABLE>
LOL think he got the point?
agreed with this man.
Old Aug 17, 2005 | 12:10 PM
b18psi's Avatar
I get his point but I wanted other peoples opinion. Thread closed. Thanks everyone
Old Aug 17, 2005 | 12:22 PM
Tad's Avatar
Tad
fyi,
incase no one mentioned it,
you would have to retune if you change your compression
Old Aug 17, 2005 | 08:10 PM
.nate's Avatar
I only use aftermarket headgaskets if I am raising/lowering the compression, or changing the bore size...
Old Aug 18, 2005 | 05:43 AM
SSBPGSR's Avatar
Default Re: (.nate)
i only use OEM. im making 360whp and have ARP's and OEM head gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NidStyles &raquo;</TD></TR><TR><TD CLASS="quote">Leave it stock, and find a better tuner.</TD></TR></TABLE>
Old Aug 18, 2005 | 05:54 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">I only use aftermarket headgaskets if I am raising/lowering the compression, or changing the bore size...</TD></TR></TABLE>
i'm using an overbored oem gasket on my 84.5mm block
Old Aug 18, 2005 | 08:12 AM
b18psi's Avatar
I live in wichita KS, their is one dyno in town and it is owned by MODIFYD who also tuned it. Where else can I go to get it tuned?
Old Aug 18, 2005 | 09:20 AM
b16sedan's Avatar
Default Re: (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">No reason to lower the compression if the motor is running ok with no detonation, and if you have no plans to turn up the boost. OEM </TD></TR></TABLE>
A blown headgasket is a damn good sign that the motor is detonating and he just can't hear it though.
