Is this block useable?
Old Apr 19, 2021 | 04:11 PM
Stopsign32v's Avatar
Loved
Default Is this block useable?
Just looking for opinions for a friend. Original B18C1 bore, rods, pistons, etc. Would be built 81.5mm with LS crank, Eagle rods, and CP pistons. Max goal of 500-530whp on original sleeves. (more than likely E85)
Damage to the block but ironically exactly where the block would have to be notched anyways...Opinions here?
Old Apr 19, 2021 | 05:26 PM
Chance EG's Avatar
Default Re: Is this block useable?
I think that should be fine, just clean up any rough edges with a dremel/sanding.
Although I'm not sure why you need to notch the block? LS crank should be "drop in" to any B18 block provided you're using the right rods and have the right bearing spec.
Old Apr 19, 2021 | 05:49 PM
Loved
LS crank + H beam rods = Need to notch
Old Apr 19, 2021 | 08:27 PM
piggy96's Avatar
I have exactly that set up and did not need to notch. B18c block, LS crank and eagle h beam rods
Old Apr 19, 2021 | 08:51 PM
highschooler's Avatar
With the piston all the way down to bottom dead center, does the bottom of the piston touch the scratched part of the cylinder sleeve? It looks like it doesn’t, so it should be alright...
Old Apr 19, 2021 | 09:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I have built a TON of this combination and have NEVER had to notch the bottom of the block sleeves.
Old Apr 20, 2021 | 03:07 AM
Loved
That’s good news! I’ve heard some need it and some don’t.
Old Apr 20, 2021 | 12:45 PM
Txdragon's Avatar
This was honestly the biggest seller of the B-series for me; not having to notch anything for forgies. Lol
Kevin
May 4, 2008 03:01 AM
Da K00l Aid Mayun
Apr 14, 2005 11:25 AM
