Block posting where to get the studs???
Old Jun 19, 2003 | 07:02 PM
JDMCRX's Avatar
Default Block posting where to get the studs???
Hye guys i want to do this to my friends block but where do we get the slugs from or what matterial??? thanks
Old Jun 20, 2003 | 07:23 AM
JDMCRX's Avatar
Default Re: Block posting where to get the studs??? (JDMCRX)
Anyone??? I need to know this asap
Old Jun 20, 2003 | 07:25 AM
mos's Avatar
mos
You will want to use aluminum. Preferably of the same alloy as the block. Sonny or ABAZ should be able to help you out with a post or two soon.
Old Jun 20, 2003 | 07:28 AM
dennis's Avatar
PM abaz - did you try a search too?
Old Jun 20, 2003 | 07:29 AM
ion_four's Avatar
Default Re: Block posting where to get the studs??? (mos)
That makes sense...I probably would've just used grade 8
Old Jun 20, 2003 | 10:07 AM
bew
Guest
Posts: n/a
Default Re: Block posting where to get the studs??? (ion_four)
From what I remember on http://www.homemadeturbo.com you can get the proper studs from Edyn.
Old Jun 20, 2003 | 10:17 AM
Sonny's Avatar
25 Year Member
Default Re: Block posting where to get the studs??? (bew)
I have an extra set that I'll sell. I had to have 25 made because that was the min amount that the machinist would do to make it worth his time. I only used 12. PM me if you want them.
Sonny
1994turbocivic
Jan 17, 2012 09:30 PM
fastboy559
Nov 3, 2007 06:00 PM
K_KrazyAzn
Dec 15, 2005 11:37 PM
sPaRk'iT
Jan 30, 2004 10:45 AM
