Blitz turbo timer insatllation
Old May 18, 2002 | 10:15 AM
FOrSfEd's Avatar
Default Blitz turbo timer insatllation
I posted this somewhere else but I'm getting no responce so maybe somebody can help me in here.
I did a search and it really didn't help me with what I need, I got a blitz turbo timer that I 'm despretly trying to install. I got everything working right except, the car dosen't stay on when I turn the ignition off, nothing stays on. Dose anybody know exactly what wire go where. I have a 88 crx hf with a b16a.
Red Wire 12 Constant
Green Wire 12 Ignition
Blue Wire Accerssary
Orange- Speed sensor
Purple- Ground/Ebrake
Where do each of these wire go to if anyone can help>
Thanks
Lee
Old Jun 4, 2003 | 06:04 PM
Hayasa15's Avatar
Default Re: Blitz turbo timer insatllation (FOrSfEd)
Bump did you figure this out? I am wondering where to get the speed sensor signal from on a cable tranny?
Old Jun 5, 2003 | 07:33 AM
Hayasa15's Avatar
Default Re: Blitz turbo timer insatllation (Hayasa15)
Old Jun 5, 2003 | 06:34 PM
Hayasa15's Avatar
has anybody hooked up a turbo timer on a car with a cable tranny?
Old Jun 8, 2003 | 02:05 AM
iiilgsrlll's Avatar
If you don't want to hook up the purple wire to the e-brake just ground it anywhere. This will probably fix your problem.
Old Jun 8, 2003 | 05:57 AM
Hayasa15's Avatar
Default Re: (iiilgsrlll)
no i am wondering about the ORANGE wire that gets tapped into the speed sensor.
Old Jun 9, 2003 | 07:52 AM
Rod.'s Avatar
Your ground is probably not hooked up right. That is what happened to me.
Old Jan 19, 2004 | 07:39 AM
Erik_Pb_Foot's Avatar
New User
let's bring this back from the dead...
I'm installing my DC Blitz Dual Turbo Timer this weekend in my 95 Integra.
I just want to verify that the wiring goes as follows:
PURPLE - Ground
2 Blacks - Grounds
Red - 12v (constant, like battery)
Blue - Accessory (at the back of the ignition, which wire is this?)
Green - 12v Ignition (which wire behind ignition is this?)
Vacuum Line - T-Tapped between.... ITM and WG ok?
Also.. I have a Viper Alarm with proximity sensors, starter disable, and a few other kills... Can anyone explain to me how my alarm and turbo timer will co-exist? Would I be correct in assuming I need to wait for the car to turn off before I can arm the alarm?
TIA
-Erik <--- confused
Old Jan 19, 2004 | 08:46 AM
TreLude's Avatar
Default Re: (Erik_Pb_Foot)
well i have a hks TT, yes you have to arm your alarm after TT shut down unless you bypass the alarm wires to the red, anyway i saved myself all the trouble of slice and dice and splice the wires by buying the 4 to 3 pin harness for $15 bucks online.
Old Jan 19, 2004 | 08:56 AM
New User
Default Re: (TreLude)
what do you mean by bypassing the alarm to the red wire? can you explain how that works?
Old Jan 19, 2004 | 03:58 PM
New User
ttt
Old Jan 19, 2004 | 06:08 PM
New User
bump
Old Jan 19, 2004 | 08:03 PM
bOOsTiNSoHcVtEc's Avatar
hey does the blitz dual turbo timer read vacuum?
Old Jan 20, 2004 | 04:02 AM
New User
Default Re: (bOOsTiNSoHcVtEc)
not the fatt timer, i don't think... but i know mine does and i have the dc. i don't have a speed sensor wire like other models do though....
bump
-Erik
Old Jan 21, 2004 | 08:25 AM
New User
nobody?
you mean all your guys put MAD money in your engines but have no alarms?
Old Jan 21, 2004 | 11:44 AM
TreLude's Avatar
i had the shop bypass the alarm wires so take yours to a stereo and alarm shop cuz they should know wat their doing cost me $100 to install w/harness
Old Jan 21, 2004 | 04:52 PM
New User
i can install it but if i arm my alarm while the car is still running with the turbo timer, my alarm is going to go off cause of the shock sensors and proximity sensors...
honda06si
14
Nov 3, 2004 08:37 AM
sporkcrx
Jun 18, 2002 01:28 PM
FOrSfEd
May 18, 2002 02:21 PM
rice4life
May 14, 2002 12:27 AM
tararan
Dec 26, 2001 09:34 AM
