Blitz SBC-ID and power meter install ?
Old Oct 6, 2004 | 05:04 PM
b18bEG's Avatar
Default Blitz SBC-ID and power meter install ?
Just finsihed my Install on both these items, and when it goes to read the MPH on the power meter, the reading is off. Would this be a cause of a lightened flywheel, I have the 12lb ACT one. TIA
Old Oct 6, 2004 | 08:44 PM
b18bEG's Avatar
id love some help with this .. anyone.. anything at all?
Old Oct 6, 2004 | 09:23 PM
PrettyLude's Avatar
it should be right because of the infrared signal they send to each other. once you have them joined, normally you would have to calibrate the speed on the power meter, but they willl be adjusted properly
Old Oct 6, 2004 | 09:27 PM
b18bEG's Avatar
no, the powere meter has 3 wires, pwr gnd, and signal, and the powere meter is the one that reads the speed, there should be no infra red transfer for the speed, should there?
Old Oct 7, 2004 | 06:18 AM
PrettyLude's Avatar
there are two sensors which are black, when you hook them up together it should ajust itself accordinly
Old Oct 7, 2004 | 09:30 AM
b18bEG's Avatar
there are 2 wires on what teh power meter or the boost controller. You must be talking about the boost controller, becuase the power meter has ONLY 3 wires, as stated above.
I called blitz NA and they said that the power meter like to be connected at the ECU, I have it connected at the sensor... I hope thats the problem, iLL find out later tonight
Modified by b18bEG at 11:49 AM 10/7/2004
Old Oct 9, 2004 | 11:14 PM
b18bEG's Avatar
got it working ....... wire must be tapped at the ECU...
Old Oct 10, 2004 | 12:59 AM
PrettyLude's Avatar
figured
itsfuckinarnell
Feb 7, 2005 11:02 AM
mr2
Nov 5, 2003 12:37 AM
Jspecek9
Aug 11, 2003 02:41 PM
