blew my b20
Old Jun 5, 2003 | 07:31 PM
TURBO B's Avatar
Default blew my b20
damn i was chillin and i think i blew it man i dont know what it is i think its the rod i was driving doing about 80 then it kicked real hard then it cut off i pulled over tried to turn it on it turned on but it made a real loud knocking in the motor so im going to take it apart tonight but tell me what yall think
Old Jun 5, 2003 | 07:58 PM
lazerus's Avatar
Default Re: blew my b20 (TURBO B)
engine is done
Old Jun 5, 2003 | 08:15 PM
Blaze45's Avatar
Brrraaaap!
Default Re: blew my b20 (lazerus)
Post pics!
Blaze
Old Jun 5, 2003 | 08:16 PM
Aquafina's Avatar
Default Re: blew my b20 (Blaze45)
Were you moving or at a stop? If moving, how much boost were you running?
Old Jun 5, 2003 | 08:45 PM
quikB18B's Avatar
Default Re: blew my b20 (SuperStreetRX7)
When my b20 went i threw rod #1 thru the front of the block, haha, i still have the block in my garage. We use it as the ashtray now. From looks of it looks like rod bolt failure, it loosened and sent the rod cap flying.
Old Jun 5, 2003 | 09:19 PM
TURBO B's Avatar
well my block is ok theres no hole in it
Old Jun 5, 2003 | 09:22 PM
racinskittle's Avatar
Default Re: (TURBO B)
Timing belt break?
Old Jun 5, 2003 | 09:57 PM
TURBO B's Avatar
Default Re: (racinskittle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">Timing belt break?</TD></TR></TABLE> nope its still good
Old Jun 5, 2003 | 10:00 PM
rOby's Avatar
just cuz theres no hole doesnt mean its still good. you could have cracked a sleeve or any numbber of things.
Old Jun 5, 2003 | 11:11 PM
TURBO B's Avatar
yeah i know
Old Jun 5, 2003 | 11:12 PM
TURBO B's Avatar
well im buying an ls motor tomorrow
Old Jun 6, 2003 | 04:16 AM
kyle h.'s Avatar
sounds like when i was cruising down the pa turnpike at about 70mph and kaboom. after i found the problem, i drove it home about 40 miles on 3 cylinders. good ol' honda.
https://honda-tech.com/zerothread?id=465714
Old Jun 6, 2003 | 11:26 AM
TURBO B's Avatar
man that sux
Old Jun 6, 2003 | 02:50 PM
gitwidit's Avatar
Default Re: (kyle h.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyle h. &raquo;</TD></TR><TR><TD CLASS="quote">sounds like when i was cruising down the pa turnpike at about 70mph and kaboom. after i found the problem, i drove it home about 40 miles on 3 cylinders. good ol' honda.
https://honda-tech.com/zerothread?id=465714</TD></TR></TABLE>
I drove home from nopi in atlanta on 3 cylinders. Over 400 miles
Old Jun 6, 2003 | 04:26 PM
TURBO B's Avatar
damn
Old Jun 6, 2003 | 04:55 PM
Drag_On's Avatar
If your on the freeway at 80 mph and you stepped on it -- I will assume you were in 5th gear.. This is THE hardest gear on your car.. there is SOOOO much load that you; probably cracked a sleeve or jacked up a psiton/rod.. 5th gear lower RPM pulls are a HORRIBLE idea.. Either downshift or go easy on it til the revs are up in 5th gear.. The load put on the motor at low R's in 5ht is CRAZY !!
Old Jun 6, 2003 | 05:47 PM
TURBO B's Avatar
damn i didnt know that that f***ing sucks thanks man
Old Jun 9, 2003 | 10:21 AM
Charlie Moua's Avatar
Default Re: (Drag_On)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_On &raquo;</TD></TR><TR><TD CLASS="quote">If your on the freeway at 80 mph and you stepped on it -- I will assume you were in 5th gear.. This is THE hardest gear on your car.. there is SOOOO much load that you; probably cracked a sleeve or jacked up a psiton/rod.. 5th gear lower RPM pulls are a HORRIBLE idea.. Either downshift or go easy on it til the revs are up in 5th gear.. The load put on the motor at low R's in 5ht is CRAZY !!</TD></TR></TABLE>
can someone please explaine this to me some more?
I've heard of it but don't really know the reasoning/physics why it's more load on the motor than a 3rd gear pull
Old Jun 9, 2003 | 10:33 AM
kommon_sense's Avatar
go back and search a few days. someone gave a good explanation late last week.
albertodsa
15
Jan 21, 2011 12:48 PM
Ek9Kiddo
20
Sep 20, 2010 07:27 PM
Damills
Feb 25, 2009 09:47 AM
MyTEC4
May 11, 2006 05:37 PM
advanracing62
105
Jan 20, 2004 04:02 PM
