Big 16G question?
Old Dec 22, 2001 | 05:31 PM
ZColeon's Avatar
New User
Default Big 16G question?
What are the differences visually on a 16G and a "Big 16G". Would this (with the use of an adapter plate) Fit on my ZC with a HF manifold. I was going to use the 14G or T25 but the 16G is bigger and Im wondering if the bolt up issue would different? thank you...
Old Dec 23, 2001 | 04:26 PM
efeezie's Avatar
Default Re: Big 16G question? (ZColeon)
The only way to really tell the difference between the 2 would be to take the compressor housing off and measure the wheel.
It has the same flange as 14b or T25, so bolt up wont be any different if you were already planning on using one of those turbo's.
Old Dec 23, 2001 | 05:17 PM
Finest's Avatar
The only difference between a 16g and Big 16g would be internal. All of the 3 turbos you mentioned would bolt up to same manifold. You might have to get the compressor side rotated, depending on your IC setup.
But more importantly, how do you like turbo lag? Cuz the 16g or Big 16g will lag, especially on a ZC.
Old Dec 24, 2001 | 08:00 AM
ih8hondas's Avatar
Default Re: Big 16G question? (Prelude_RCR)
The only difference is the compresser wheel size. The 16g compresser wheels exducer size 2.365 and inducer is 1.830 as compared to the big 16g its exducer is 2.680 and inducer is 1.892. and the flow is 505cfm for small and 550cfm for the big
SPOOLINmatt
Dec 21, 2005 09:31 AM
SOHCex20
May 18, 2005 04:18 PM
_Endless_
Aug 8, 2004 05:40 AM
BodyKits NW
May 18, 2004 07:55 PM
DaX
Mar 23, 2004 03:15 PM
