In-between a 5857 and 6262? - 600whp goal
Old Oct 17, 2010 | 12:58 PM
mofia77's Avatar
Default In-between a 5857 and 6262? - 600whp goal
Hey guys, I'm looking for a turbo inbetween a precision 5857 and a 6262. Goal is approx. 600whp but with the best area under the curve/spool.
Still working on the setup but will likely be:
b18c GE sleeved block 84 bore
LS micro-polished crank
b18c type R head
CTR cams
supertech valvetrain
cp 9.7:1 pistons - may use a cometic .040" to drop this to approx. 9.4:1 because of poor gas
manley h-beam rods or turbo tough i-beams
car will be a DD - nothing more than 400whp on pump, but on race gas I'm looking for around 600whp, goal is mid to low 10sec. I don't however subscribe to this big turbo mentality to shoot for 700whp only to drop 100+whp in-between gears
I'm thinking this might be a bit much for a 5857, any recommendations?
Where's Mr Shodan @?
Old Oct 17, 2010 | 02:44 PM
ghostskinner's Avatar
Default Re: In-between a 5857 and 6262? - 600whp goal
get the 6262 for 600whp mikey
Old Oct 17, 2010 | 02:50 PM
Boosted-EH-804's Avatar
Hands down 6262
Old Oct 17, 2010 | 04:48 PM
spectacle's Avatar
no question 6262
Old Oct 17, 2010 | 05:19 PM
1992db2's Avatar
5857 would be too small. 6262
Old Oct 17, 2010 | 06:18 PM
runsfromdacops's Avatar
6262 all the way. you will make 600 np. and it will give you some head room to turn it up later down the road, and you WILL end up going for more after you drive the car on 600 for a week of 2.
Old Oct 17, 2010 | 06:22 PM
mtber's Avatar
6262
Old Oct 17, 2010 | 06:31 PM
mofia77's Avatar
I know the 6262 can make it...just wondering if there is a size between the 5857 and the 6262, customer is looking for an option that's fun on the street as well.
Old Oct 17, 2010 | 07:15 PM
AlexDphoto's Avatar
I think theres a 6062
Old Oct 17, 2010 | 09:38 PM
AllShowNoGo727's Avatar
I Was looking for similar goals i went with the 6262 ball bearing with the ported cover. .63 exhaust housing and vband. Spools quick and is a nasty turbo.
Old Oct 17, 2010 | 09:53 PM
Zer0_SpeedWorks's Avatar
6062 or better yet 6262...
6262 gets my vote also
Old Oct 17, 2010 | 10:21 PM
ScorpionT's Avatar
With the right setup, the 5857 could pull it off. It will need to be pushed a bit, but it can be done. The 6062 isnt built anymore, so the next step is a 6262.
Old Oct 18, 2010 | 07:50 AM
E85B18's Avatar
You can't have quick spool and 600whp. Not possible. If it's a street car go with the 5857 and get close to 600. It really just depends on the purpose of the car but a 6262 is not the best on the street
Old Oct 18, 2010 | 08:19 AM
SovXietday's Avatar
There's a 6062, going to have to push it to go over 600. The 6262 will make 600 a lot easier and have some room to spare, which if I've learned anything from doing this, having room to spare is always a good thing.
Old Oct 18, 2010 | 02:46 PM
mofia77's Avatar
not expecting t3/t4 57trim like response..but rather say a turbo that can be pushed to make 630whp vs the 6262 which I understand is a 700whp turbo
Old Oct 18, 2010 | 02:52 PM
2k.civic.si's Avatar
the 6062 maxes out around 650hp....it wont make 600whp without pushing it to hard.
go for the 6262
other choices are
GT3788R
Turbonetics GTK-650
im amazed the shodan hasnt come in here and listed off a bunch of turbos yet.
Old Oct 18, 2010 | 04:29 PM
mofia77's Avatar
Do you have any dyno sheets?
Old Oct 18, 2010 | 04:32 PM
mofia77's Avatar
go for the 6262
other choices are
GT3788R
Turbonetics GTK-650
Was also considering a HTA 35R from Forced Performance - think that can make the 600whp?
Old Oct 18, 2010 | 04:35 PM
hondacrxhf's Avatar
buy my turboo!!!!
Old Oct 18, 2010 | 04:43 PM
BlakeJ53's Avatar
I have pretty much the same setup as you and I put down 610 at 21psi with a 6262 with a 82ar exhaust housing at speedfactory. Its a great turbo!
Old Oct 18, 2010 | 04:52 PM
pgpbubble's Avatar
this should answer your question or give you an idea.
https://honda-tech.com/forums/forced-induction-16/billet-62-62-vs-bbt72-dyno-2697837/
Old Oct 18, 2010 | 05:18 PM
Ill post new dyno by the end of this week gonna have it tuned on pump gas and c16 by member mtber. here is a pic of when i bolted my 6262 on my manifold.
Old Oct 18, 2010 | 07:38 PM
E85B18's Avatar
Don't go with the 6062. Go with the 6262.
Sweet turbo. Talk to the Shodan
Old Oct 18, 2010 | 08:03 PM
can you see the difference? the center of the hta where the shaft goes through is smaller allowing the blades to be slightly longer (was told about 3mm difference)
again i dont like the idea of pushing a turbo to its limits....it wont live as long as a porperly sized turbo not working as hard.
go for the 6262
other choices are
GT3788R
Turbonetics GTK-650
Old Oct 20, 2010 | 08:11 PM
mofia77's Avatar
that's exactly what I'm looking for...a "properly sized turbo" for 600whp, that will give me the best area under the curve...doesn't necessarily have to be "off the shelf"
