Which is better? te04h or T25? and why.
Old Jan 8, 2006 | 04:05 PM
smash fascism's Avatar
Default Which is better? te04h or T25? and why.
Im looking into buying one of these, which one is bigger? its going to be going on a 87 crx with zc swap. I want to run about 7-8Lbs of boost.
Thanks in advance, smash
Old Jan 8, 2006 | 04:07 PM
AbitAvenger's Avatar
get a td05h / 14b off of a dsm, perfect for the zc
Old Jan 8, 2006 | 04:16 PM
civicsitek GanGsTa's Avatar
Default Re: (AbitAvenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger &raquo;</TD></TR><TR><TD CLASS="quote">get a td05h / 14b off of a dsm, perfect for the zc</TD></TR></TABLE>
did you even read the question? I personally went with a te04h, but I will admit I have no idea which one is bigger. I looked at the compressor map for is but it was a scanned map and didnt show up well so it didnt give me the info I was after.
Old Jan 8, 2006 | 04:34 PM
highroller54's Avatar
Default Re: (civicsitek GanGsTa)
what t-25?
Old Jan 8, 2006 | 04:36 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsitek GanGsTa &raquo;</TD></TR><TR><TD CLASS="quote">
did you even read the question? I personally went with a te04h, but I will admit I have no idea which one is bigger. I looked at the compressor map for is but it was a scanned map and didnt show up well so it didnt give me the info I was after. </TD></TR></TABLE>
Actually, neither is good for that ZC motor (of course that depends on what goals you're looking to accomplish) But the Mitsu TE04H is slightly small in the inducer compressor than the Garrett T-25.. Most TE04Hs are most configured w/ a 12A turbo, which is made for immediate torque at a low compression without the need of any top end. Your ZC motor flows over 90cfm more efficiently than the motor it was originally intended for. You can't go by7-8psi on either of these turbos, the cfm capacities of either turbo allow for a bit more boost to be used, as long as fuel issues have been properly addressed
jwd
Jan 12, 2008 05:58 PM
dipsetking
Jun 26, 2007 01:37 PM
jeezyskillz
11
Jan 6, 2007 11:38 AM
eagleclawracing
25
Jan 26, 2006 06:20 AM
d16X
Oct 16, 2004 10:44 PM
