Best way to tell detonation
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">I was under the impression that even coasting with the engine rotating via wheels spinning coudl change the way the plugs looked as well?</TD></TR></TABLE>
No it does not since the fuel is cut off when you switch off ignition. Also when you let off at high rpm the fuel is cut to the injectors and all stock ECU do that.
Hello.
I´m from Germany, but we developed a system that can tell you detonatin. It works with a additional knocking sensor and a special interface box and of course a special software for on laptop.
It works with a special frequene analizing system that shows you a begining knocking before your ears can hear it and before it becomes dangerous for your engines.
Feel free to ask for further informations
Kevin
PS: In moment, we run it on our own turbo b16/b18 and supercharged b20
http://www.mkr-turbo.de.vu
Kevin
spunautosports
30
Jan 1, 2007 12:07 PM
