best spark plugs
Old Oct 21, 2012 | 04:24 PM
duf2570's Avatar
Default best spark plugs
so my tunner here said to me that use iridium spark plug on my setup isnt good for me...im in the process to change them...what is the best plug i can install???now im with bkr7e standar plug gapped to .32..and boost to 18 psi with meth
Old Oct 21, 2012 | 07:17 PM
MRGRIM's Avatar
R.I.P. Mark
Default Re: best spark plugs
that does not make sense Iridium works better than stock ?!? (BKR7IEX )
but not the bkr7iex-11 way to big of a gap .45
smaller gap would help like .28
more details on setup
Old Oct 21, 2012 | 07:18 PM
wantboost's Avatar
Who is Mr Robot?
your tuner is an idiot
Old Oct 21, 2012 | 11:58 PM
rich7777's Avatar
What was the tuners reason ?
Old Oct 22, 2012 | 01:12 AM
duf2570's Avatar
the reason...ishhh when he told me that i just dont listen him annymore about tunning,,so i always used bkr7iex-11 (regapped to .28) in my other car...this is why i was confused...
forged b18b comp ratio.. 8.3:1
wiseco piston(dont know the compression ratio)
ferrea valves/spring/retainer
j.e rod
3 inch intercooler and piping
exhaust and intake ported head
Blackworks welded block guard
victor-x intake
spec-r trottle body
crower cams
aem cam gears
ss equal lenght manifold
gt3071 garrett turbo
800cc BOSCH EV14 injectors
aem progressive watermeth injection kit
38mm turbosmart wastegate
tial blow off
mishimoto radiator
rs tranny with quaife lsd
exedy stage 2clutch(i dont do drag and lapping)
full 3 inch downpipe/exhaust
pyro/boost/oil temp/oil pressure/watertemp pro comp gauge
innovate wideband
ive got on 91 oct(we only have this here) and meth(50/50 mix) 18 psi 370 whp and 320 lbs and this is my local tunner (not the best)
Old Oct 22, 2012 | 11:16 AM
MRGRIM's Avatar
R.I.P. Mark
BKR7IEX-11
is not a good plug to use as your stressing the plug to get the gap you need
try useing BKR7IEX its .32 to start with so its only a small adjustment to .28
^^ this is the same thing i recommend to the JRSC guys and use myself
Old Oct 22, 2012 | 12:57 PM
kbouchard1092's Avatar
I normally just go with BKR7E there like 1.38 Each....
Is there really any benefit going with iridium? Also at what point would you say a heat range 8 would be recomended?
im at 480whp now w/ small amount of no2. i would think im at the upper limits of the 7 heat range....Debating on dropping to the bkr8e...possibly iridium.
Old Oct 22, 2012 | 06:33 PM
wantboost's Avatar
Who is Mr Robot?
Stronger spark, smaller electrode so it takes less energy to produce a spark so more energy goes into the spark
Old Oct 22, 2012 | 08:37 PM
MRGRIM's Avatar
R.I.P. Mark
I would suggest to answer all your questions
http://www.ngk-elearning.com/
it takes a bit to load correctly sometimes reset the page
but click on spark plugs and you will learn all the facts you will ever need to know
and at the end get a certificate for it
Old Oct 23, 2012 | 04:51 AM
Makes sense... I might try iridium this time around (bkr7iex) I run OEM ignition usually im free of break up with about .022ish gap with the bkr7e. Maybe ill try slightly higher with the Iridium.
Going to stick with the 7 heat range.
Old Oct 23, 2012 | 05:02 AM
MrGrim, That e-learning is great! Lots of Good information on there
Old Oct 23, 2012 | 10:56 AM
MRGRIM's Avatar
R.I.P. Mark
Im glad you liked it and you can do all the courses and print out the certs at the end to put up on the workshop wall
and they are offical NGK training not just info
Old Oct 23, 2012 | 11:27 AM
Yeah its definatly legit... Very informative. Bookmarked
I actually just ordered the Bkr7iex too try the iridium plugs out
Old Oct 23, 2012 | 11:52 AM
Muckman's Avatar
Moderator in Chief
Old school turbo knowledge said iridiums were bad for FI. We've proven this to be wrong and made more power vs standard electrode at same gap. Unfortunately the iridium plugs are 4-5x the cost of standard plugs.
Old Oct 23, 2012 | 11:54 AM
TheShodan's Avatar
Moderator
Exactly. I tend to change between the 4554 and the 2668s like you stated in the previous thread. But for street use, even the BK7s can still work.
Old Oct 23, 2012 | 11:57 AM
Muckman's Avatar
Moderator in Chief
Why is the resistor option so expensive? I wish there was a 5k resistor I could run inline with my plug wires so I could run the 4554 racing plugs.
Old Oct 23, 2012 | 12:19 PM
TheShodan's Avatar
Moderator
No idea other than that Iridium is extremely expensive as an element.
For racing I use an even more aggressive GReddy plug.
Old Oct 23, 2012 | 12:31 PM
At what power level would you suggest to upgrade to the 8's? i know im at the limits of the 7's but its a street car so figured i stick to the 7's.
Old Oct 23, 2012 | 12:41 PM
Muckman's Avatar
Moderator in Chief
Well its heat based, not power based. Pull the plug out and read the grounding strap. You want the annealing mark to be right in the middle.
Old Oct 23, 2012 | 12:43 PM
Im thinking i would be fine with the 7's, but once im using NO2 im sure id be benefiting from the 8's.
I will check the old plugs when i take them out
Also the grounding strap is more for reading timing correct? The burnt threads at the end of the plug are suppose to dictate heat range.. 2-3 threads ideal...4-5-6 you need a colder plug
Old Oct 25, 2012 | 11:23 AM
Steeve_Civic's Avatar
I use Denso IK24 plugs on my B18C1 T6766?
Is it good?
Old Oct 25, 2012 | 12:30 PM
Is it good?
WEll thats a 8 heat range...you would think its ok...but thats a big *** turbo!
You may even need 9's really only way to know is too read the plugs and see if it needs a colder step..
Sounds like your's clearly is not a street car so maybe 9's would be better....jmo
Old Oct 26, 2012 | 02:04 AM
h22-eg-hatch's Avatar
NGK v power 9 (h22 turbo 91 octane 6psi daily gapped to 20-22)
Old Oct 26, 2012 | 08:26 AM
Yes not a street car so I need to go with Denso IK27 or BKR 9??
Old Oct 26, 2012 | 12:53 PM
wantboost's Avatar
Who is Mr Robot?
That's because our only source of iridum is from meteorites that hit earth forever ago. It takes very advanced mining methods to obtain as well. The cost of turning the raw ore into an electrode is also costly given the materials hardness. On the plus side though this hardness means that for a given application the iridium electrode will provide a longer service life vs. A standard electrode.
