Best motor to boost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GuCCi_GSR »</TD></TR><TR><TD CLASS="quote">Can a B20 handle 7 psi?</TD></TR></TABLE>
as long as you tune it right, probably. remember, boost in big turbo is different than boost in a small turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgredteg »</TD></TR><TR><TD CLASS="quote">LS motor I think would be best to boost considering you wanna use stock internals</TD></TR></TABLE>
or ls vtec
or ls vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GuCCi_GSR »</TD></TR><TR><TD CLASS="quote">why is LS (b18b) better than a CRV (b20)?</TD></TR></TABLE>
B20 is a bored out LS. Thinner sleeves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG »</TD></TR><TR><TD CLASS="quote">
B20 is a bored out LS. Thinner sleeves.</TD></TR></TABLE>
No it's not. The B20's have thicker sleeves, but the design make them extremely weak. Don't waste you time on stock B20 sleeves, they are garbage, anything that tells you different doesn't know what they are talking about. Search and you will see plenty of info as to why they are crappy.
The best motor to boost? There is no such thing, but the B18c1/5 (GSR and ITR) are the best all around motors honda made in my opinion. You can use those motor for just about anything. Good r/s ratio, good stock heads and cams, and not much is needed to make big power with them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">
The best motor to boost? There is no such thing, but the B18c1/5 (GSR and ITR) are the best all around motors honda made in my opinion. You can use those motor for just about anything. Good r/s ratio, good stock heads and cams, and not much is needed to make big power with them.</TD></TR></TABLE>
Well said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">No it's not. The B20's have thicker sleeves, but the design make them extremely weak. </TD></TR></TABLE>
Word. Didn't know that. I just mess with crappy SOHC engines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">The best motor to boost? There is no such thing, but the B18c1/5 (GSR and ITR) are the best all around motors honda made in my opinion. You can use those motor for just about anything. Good r/s ratio, good stock heads and cams, and not much is needed to make big power with them.</TD></TR></TABLE>
Agreed.
Agreed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy »</TD></TR><TR><TD CLASS="quote">GSR...</TD></TR></TABLE>
I dont think there is a better answer then that
teggyjeff
Oct 30, 2008 03:26 AM
JDMroyEG5turbo
15
Mar 3, 2006 03:01 AM
ragerized
35
May 10, 2004 12:22 PM
