Best ECU for Uberdata?
Old May 18, 2004 | 03:08 PM
VanHonda's Avatar
Default Best ECU for Uberdata?
I have searched and cant find exactly what I am looking for. I have a 2000 si and want to run uberdata, so I know that I need to swap back to OBD1. My question is which ECU is best? The p28 is alot cheaper, but lacks the knock sensor. Is this a big deal or is it ok to run the p28 and forget about the knock sensor? Also are there any other options for ECU's for me besides the p28 or p72?
Thanks,
Craig
Old May 18, 2004 | 03:16 PM
Joseph Davis's Avatar
Default Re: Best ECU for Uberdata? (VanHonda)
**** a Honda KS, the implementation of it makes it for adjusting ignition timing under cruise to avoid NOx production and get Honda more LEV ratings. It has absolutely nothing to do with engine safety, tuning, or how your car runs; the ECU ignores it at WOT or above 5000 rpms.
Old May 18, 2004 | 03:44 PM
ndogg's Avatar
you could also run a p30. those also have knock sensors (came from vtec delsols). but like j davis said... who cares? get whats cheapest of those 3. wich will probably be the p28.
Old May 19, 2004 | 11:55 AM
drewbie*'s Avatar
Default Re: Best ECU for Uberdata? (ndogg)
just get a cheap ecu. I am going to run uberdata on my p05 (cx)
Old Jul 3, 2004 | 08:45 AM
blacksheep's Avatar
so will it run on any obd-1 ecu? i have a 94 ls and want to know if i can use my stock ecu with uberdata when i put on my turbo setup.
Old Jul 3, 2004 | 09:16 AM
TurboJesse
Guest
Posts: n/a
Default Re: Best ECU for Uberdata? (blacksheep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacksheep &raquo;</TD></TR><TR><TD CLASS="quote">so will it run on any obd-1 ecu? i have a 94 ls and want to know if i can use my stock ecu with uberdata when i put on my turbo setup.</TD></TR></TABLE>
yes your stock ecu will be fine.
Old Jul 4, 2004 | 03:49 PM
blacksheep's Avatar
Default Re: Best ECU for Uberdata? (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">
yes your stock ecu will be fine.</TD></TR></TABLE>
thanks for the quick answer
Old Jul 4, 2004 | 04:52 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
can you run uberdata on a P07? 92 VX? i might be intersted in this... hrmmm... ::looks off into the distance:: lol
Old Jul 4, 2004 | 07:23 PM
Default Re: Best ECU for Uberdata? (Built B16A)
P07 is odd duck, the second MCU that controlls WBO2 input polls the primary MCU with interrupts that make it run wierd. VTEC transition is erratic and upper revs are soggy, IME.
Old Jul 4, 2004 | 07:25 PM
Built B16A's Avatar
Default Re: Best ECU for Uberdata? (J. Davis)
im just trying to work with what i got..
ok.. so if i per say, went with a P28.. would i have to re pin my plug on the O2, and get a 4 wire? hows that going to switch back?
LUDEcidDream
Engine Management and Tuning
Jul 19, 2010 02:01 PM
team 15
Jan 11, 2007 05:59 AM
dthug
Mar 26, 2006 06:15 PM
EJ1_203
Jul 23, 2005 04:48 AM
SETI20
Aug 17, 2004 11:57 AM
