Bent Compressor Fin
Old Jun 27, 2004 | 09:54 PM
StrangerWitCandy's Avatar
Default Bent Compressor Fin
ok, ive searched but cant find anything.
the tip of one of the fins on the compressor wheel of my T3/T4 is slightly bent
its about 5mm of the tip of the fin and is bent about 40 degrees out (towards the inlet) its hard to see in the pics, but they might help.
im wondering if it will affect its performance much, should i try bending it back with some pliers? should i just leave it? or should i replace the wheel? the latter would be very unwanted since i would like to get this thing in withing the next week or so.
thanks for any help!
Old Jun 27, 2004 | 10:01 PM
Blind-Fashion's Avatar
my friend actually had one that ate a FEW rocks.. and it had some fucked up fins.. he dynoed at 278 with the bent fins( and chewed up) and we replaced the wheel and he dynoed at 285.. and i mean it was fucked up.. so i dont think that the bent fin you have their is going to affect much ( i mean high hp aplications would probably make a HUGE differance) just use it! and of course have fun with it!
Old Jun 27, 2004 | 10:41 PM
The Destroyer's Avatar
Default Re: (Blind Fashion)
Maybe you can take the comp housing off and try to bend the fin back a little.
Old Jun 28, 2004 | 07:41 AM
Default Re: (Vtaaak y0)
yeah Vtaaak, i was thinking about that (its why i asked if i should bend it back) the only thing im worried about is if the metal got deformed at all or anything, if i bend it back it might scrape the housing... and i wouldent want that!
Old Jun 28, 2004 | 07:48 AM
SiRkid's Avatar
Default Re: Bent Compressor Fin (StrangerWitCandy)
that probably is effecting it quite a bit
Old Jun 28, 2004 | 07:52 AM
Chillinit's Avatar
Default Re: Bent Compressor Fin (SiRkid)
it might throw that sucker out of balance!!
Old Jun 28, 2004 | 07:59 AM
boosted_dc2's Avatar
Default Re: Bent Compressor Fin (Chillinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">it might throw that sucker out of balance!! </TD></TR></TABLE>
exactly what i was thinking, remember the wheel spins at like 1,000,000,000,000 rpm's
Landon
Old Jun 28, 2004 | 08:27 AM
Tinker219's Avatar
Default Re: Bent Compressor Fin (boosted_dc2)
my perfectly fine SC61 took chumped out at 22psi, Im assuming because I maxed out the efficiency of it somehow. so ya, 150k RPM is a good starting point for these things...hehe
Old Jun 28, 2004 | 12:48 PM
Default Re: Bent Compressor Fin (Tinker219)
so what do you think i should do? try to bend it back?
Old Jun 28, 2004 | 12:59 PM
Joseph Davis's Avatar
I'm hesitant to bend on it any more, because I have no real experience withthe metallurgy of a compressor wheel.
If it were me, I'd toss a coin to decide if I was going to run it as is, or have it rebalanced as is and then run it.
Dasanib20T
Oct 16, 2008 12:40 AM
doc
Dec 26, 2005 05:25 AM
Wideopentuning
Jul 15, 2004 07:44 PM
Stock@$$GSR
Apr 18, 2002 06:22 AM
