Bearing clearances
Old Aug 31, 2011 | 11:53 AM
LightningTeg's Avatar
Community Builder
Default Bearing clearances
What kind of bearing (rod and main) clearances are you guys running in the high hp setups (400whp+)?
I've read to shoot for 15-20 thousandths to be on the looser side aka safer
Old Aug 31, 2011 | 01:47 PM
rich7777's Avatar
Default Re: Bearing clearances
I'll be running .0018 for the mains & rods in the forged block i'm building.
Old Aug 31, 2011 | 02:17 PM
blackeg's Avatar
Between. 0018 and. 0020. Id also recommend a ptw tolerance of at least. 0045. That's where im at with 475hp and so far so good. I had some ptw issues on the dyno with. 0035. I also had a rod bearing at about. 0015 that was on its way out fast with only 2500 miles. Good thing I found it b4 it spun
Old Aug 31, 2011 | 02:27 PM
Community Builder
Im just rebuilding a block that ate a bearing a few months ago. It had a good 15-20k miles on it then I think it over boosted.
Same pistons just fresh hone, rings, bearings, and crank.
Old Aug 31, 2011 | 08:38 PM
4cylfiend's Avatar
My mains are 0.0020 and my rods are at 0.0015. My ptw is 0.0055 on all cylinders.
Old Sep 1, 2011 | 05:31 AM
lsturbo33's Avatar
Just so you know 15-20 thousandths is .015-.02. What you meant was one and a half to two thousandths .0015-.002. I would stay on the looser side of that tolerance though .0018-.002 especially since your running high boost. I'm assuming this is your sleeved motor i saw in the ls-t thread?
Old Sep 1, 2011 | 07:53 AM
Community Builder
Ya
Old Sep 1, 2011 | 08:39 AM
Gunmetal_B20_Hatch's Avatar
this
and PTW around .003-.004
Old Sep 1, 2011 | 09:26 AM
Community Builder
is there a way to check without a dial bore gauge for PTW?
Old Sep 1, 2011 | 10:24 AM
sleepencivic's Avatar
you need a 3-4 inch outside micrometer for measuring the pistons and then the dial bore gauge for the block... then do the math.....I will rent you mine LOL...
Old Sep 1, 2011 | 10:30 AM
Community Builder
Your saying a good micrometer measuring the top of the cylinder isnt good enough? Its at the machine shop now so I'll know if its out of round
Old Sep 1, 2011 | 01:52 PM
Turbo-LS's Avatar
I like to run stock bearing clearences with or without oem bearings. If your not going to change oil weight then why run anything looser than stock specs ?
Old Sep 1, 2011 | 04:06 PM
No its not. You should measure the entire bore from top to bottom and then again 90 degrees from the first with the dial bore gauge.
Old Sep 2, 2011 | 01:17 AM
wolve's Avatar
just run near the service limit on the stock specs, why?
more then stock rpms require more then stock clearance for more then stock cooling. don't overload the oil/bearings for a 200.000miles longevity your not going to use.
Old Sep 2, 2011 | 04:41 AM
Turbo-LS's Avatar
ive never had any bearing issues running the loose side of stock clearence and 10w30 motor oil with 9200rpm and over 400whp
Old Sep 2, 2011 | 01:46 PM
IN VTEC's Avatar
Yeah same here. 0.0020" to 0.0025" clearance on the mains and rods with 10W-30. Lasted 2+ years until it cracked a ring land during a cold night at the track. The motor did a 11.2 @ 130mph that night.
cjonescrx
10
Aug 2, 2012 04:41 AM
90ZCREX
Sep 3, 2011 11:47 PM
n/a_kong
Jul 2, 2010 06:52 AM
ziggy3784
Apr 30, 2009 07:48 AM
hybrid901
Mar 17, 2003 11:43 AM
