BBK Intake manifold
Old Mar 12, 2010 | 06:15 AM
civ9317's Avatar
Default BBK Intake manifold
Soley for information purposes. long reading
So, i am looking for a intake manifold for my turbo build. Edelbrock is common i know but i was like hell i will try the BBK out.
I get it. Looks great. It doesn't look any worse or better than the edelbrock my friend used (as far as casting and finish).
I start putting things together (everything fit great) go to put it on my B16 head and BAM!!!! thing don't fit.
Has anybody else used this manifold? on a b16?
I searched and there where people back in the day using it but they said it was for a GSR motor.
BBK says something different!
Product description below directly from bbk.
For less than three hundred dollars – Import owners of Honda’s popular 1.8L engine equipped models can now bolt on this beautiful all new SSI Series performance intake manifold. Designed to deliver great all around performance gains – our new manifold on the street or the track delivers the best performance value in the aftermarket.
Starting with lightweight 356 aluminum casting, each intake manifold is fully computer machined for OEM quality levels and features a standard 70mm throttle body opening to accept units such as our popular Power Plus Series performance throttle bodies. This manifold comes standard in a great looking metallic charcoal powdercoat finish.
Each intake manifold model has been designed and dyno tested in Southern California to maximize performance at a low cost to the consumer.
Please Note:
5007 manifold is intended for B18C5 engines (type R) but will also fit B16 (1.6L vtec) & B17 (1.7L vtec)
5007 DOES NOT fit B18C1-GSR (1.8L vtech).
Hatchorama
Jun 11, 2007 04:40 PM
shutdown
13
Jul 23, 2005 03:19 PM
daidilus
Welding / Fabrication
Oct 24, 2004 11:25 AM
MonkeyManStunna
Aug 8, 2004 01:24 PM
BrokdwnCrx
18
Nov 19, 2002 09:53 PM
