BB t28 good for a d16z6?
Old Aug 12, 2006 | 12:08 AM
broketuner-Sol_Si's Avatar
Default BB t28 good for a d16z6?
As some of you know I plan on turboing my d16 in my sol. The main thing I'm undecided on is the turbo. I've been considering running a dsm turbo, but have found very few in even a rebuildable condition for a reasonable price, if I'm going to buy a used turbo the most I want to spend is 250-300. I found a very good deal on a t28 ball earing turbo, but it does need a rebuild. The reason I' considering it is because it's BB and will spool quicker. My ? is will this turbo easily support around 200-225whp (the motor will have IM, TB, cam, and tuned on crome pro...I don't plan to build up the motor because of how cheap replacements are.)
Old Aug 12, 2006 | 02:12 AM
pgmatt's Avatar
Default Re: BB t28 good for a d16z6? (broketuner-sol_si)
That is about the perfect turbo for a d16 Ball bearing turbos require a new center section and you should research what that will cost before you buy it.Might want to price a new one.A T3 .48 .60 works well too if you want quickish spool.
Old Aug 12, 2006 | 03:13 AM
1epmugenlude's Avatar
I think it will work out fine. I believe this will support your goal as well.
Old Aug 12, 2006 | 12:35 PM
EK k kay's Avatar
If you can get it for that price go for it. I'm using a T3 .60/.48 and it would be perfect for your goals. Gets 10psi at 3800rpms. I'm making somewhere around 220whp and it's still got plenty more left in it.
Old Aug 20, 2006 | 12:32 AM
integracivic94's Avatar
Default Re: BB t28 good for a d16z6? (EK k kay)
i had a t28 on my d16z6 worked great you'll love it! should easily net you 225hp i think there good upto 300hp depending spec!
Old Aug 20, 2006 | 08:20 AM
Default Re: BB t28 good for a d16z6? (integracivic94)
well assuming the damn thing can be rebuilt it has a .60a/r and hs M24 on it. According to the prevous owner of it it'll be good for up to 18lbs, butwho knows how good that really is because according to a few people after taking a look at it it might not even be rebuildable
MattsLegit
13
Jan 23, 2015 02:09 PM
Sleeper88Civic
Jan 4, 2010 05:14 PM
streetlvlhatch
Jun 20, 2005 02:49 PM
EJ1 wilcox
Apr 22, 2004 08:02 AM
SleeperCX
Apr 4, 2004 08:48 AM
