bad turbo seals
Old Feb 21, 2002 | 08:04 PM
808eg6's Avatar
Default bad turbo seals
if your turbo seals are bad would there be oil all around the downpipe. my down pipe is loose because i'm missing some bolts and seems to be smoking from there and from the exhaust but no leaks. at idle it blows white smoke for a minute or two at the most then goes away but that is the only time it smokes. it has gotten significantly worse in the past few days, meaning it happens more frequently now. could it be from a kink in the oil return line. if it could be a kink what would you consider a kink. would it be very noticeable. looks like my return line has a small kink thats why. also it is not a coolant i did a compression test and it was fine and the smoke smells like oil.
thanks in advance for any help
T--Rex
May 29, 2005 11:24 AM
S2KP
Dec 25, 2003 10:52 AM
01ITR#700
Aug 7, 2003 06:25 AM
pelotudo
Aug 25, 2002 07:50 PM
TurboIntegra
Jul 24, 2001 12:32 PM
