bad turbo???? NEED HELP!!!!!!!!!!
I bought a garrett t3/t04e from 035psi on here and i got it today. I took the compressor housing and turbine housing to look at the blades,measure the wheels to confirm i got what i paid for and as i take out the compressor housing i saw a bit of oil inside.
then I take off the turbine housing off and the round piece right behind the wheel is loose. it spins and it moves a bit up and down.
**NOTE** theres no shaft play and he said it didnt have alot of miles and doesnt look like it but you never know.
Modified by 90 integra at 12:20 AM 1/19/2006
atleast put the turbo on if you are trying to see if it smokes or oil is leaking past the seals. Even with oil there you are not 100% sure it is leaking oil or smokes. As far as size bust out the caliper and do a little research on the internet. Good luck man wish I could help you.
that round part behind the turbine wheel is normally loose when you remove the housing, its there as a seal, to keep the exhaust out of the center section, when you reinstall the turbine housing it will hold it in place.
theEGkid
Sep 22, 2005 10:44 AM
