bad idle when warm
Old Oct 6, 2003 | 11:36 AM
JrCRXHF's Avatar
Default bad idle when warm
I think my problem is with the fast idle control but i do not want to go buy one not unless i am sure that is what the problem is seeing they are 180 dollars. I have a 88 rex HF with a B16 stock with a t3/t4 turbo if that makes a difference i have hondata stage 3b when i put a wide band in the car it has the right air to fuel but the rpms go up and down about 250rpm anyone know for sure what the is.
Old Oct 6, 2003 | 02:45 PM
JrCRXHF's Avatar
Default Re: bad idle when warm (JrCRXHF)
bumb
Old Oct 6, 2003 | 02:53 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Yes it's the fast idle.........goes ............up.....then a drastic drop. That part cost $70 from Acura. Take it off. shake it. If you hear it rattle it's no good. Otherwise it can be adjusted. Honda says it can't but it really can it's been done before. Good question.
Old Oct 6, 2003 | 05:47 PM
JrCRXHF's Avatar
Default Re: bad idle when warm (HybridcivicLS-T)
how do you adjust it is it with the alen screw on the end
avrfan
10
May 11, 2015 11:41 PM
Tyrant_007
Mar 28, 2011 08:01 PM
jdmstyleg
Oct 15, 2009 06:55 PM
BrokenRex
Oct 13, 2005 08:25 PM
