Back from the dead.....almost ready for boost again......some pics
Just need to get my clutch and tie up some minor details
http://www.imagestation.com/album/?id=4291253395
Thanks everyone!.............I blew the motor in April, so it has been quite a while.
It's a Max Rev manifold. I should have done it this way the first time......live and learn.
Very nice man.
Like the painted back end. Flat black?
Is your battery in the trunk too?
Also, im just curious of why you got the filter relocation thing? Is it for purley easier access?
Thanks dude! Yep, flat black..........I'll send ya a pic or two of the battery.
Well, the convenience of changing the filter up there is nice. Plus, my turbo is water cooled, so I used the stock oil cooler lines for the coolant lines to and from the turbo. It also made it a little easier to run the oil cooler and thermostat and it's something different.
integramodder@comcast.net
Hold it, that is the driver side rotor.......you think it's backwards?
http://hp.brembo.com/edit/faq/index....D&PrCatID=3#31
Additionally, all of Brembo's slotted discs are directional as well, regardless of the vane geometry. The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first. Please see figure.
