B20VTEC Ready for boost- Hondata MAP?
Old Jan 4, 2003 | 11:19 AM
hybridsol's Avatar
Default B20VTEC Ready for boost- Hondata MAP?
I got everything ready to roll, had a time getting through emissions inspection, turns out it was a bad distributor! Anyway, I was going to slap the turbo on tomorrow, just wondering is someone can give me any suggestions on TIMING map for the engine. I'll set the timing at crank to 16 deg (like stock). I'm not concerned about the fuel maps, I have the DIY wideband already. I can use the DRAG map included if no one has any suggestions.
Specs:
B20B/VTEC ported head+enyne springs/ Skunk2 intake
2mm head gasket (9.0 CR)
440 cc RC injectors
F-max kit less aux injectors, 9 lbs boost spring/ tail wase gate
Stock bottom end; 7500 RPM redline set through Hondata
My ROM tune now (pretty close, running in closed loop)
http://home.earthlink.net/~tailwags/B20VTEC_NA_240.bin
The turbo Pic:
Thanks for everyone's help.
Sean
Old Jan 4, 2003 | 11:31 AM
I Like Boost's Avatar
Default Re: B20VTEC Ready for boost- Hondata MAP? (hybridsol)
nice setup, but that dumptube commin from the wategate should be much further down.
Old Jan 5, 2003 | 05:27 AM
hybridsol's Avatar
Default Re: B20VTEC Ready for boost- Hondata MAP? (BEe18SeAONe)
Selfish Bump... Anyone?
Old Jan 5, 2003 | 11:16 AM
stevecockrill's Avatar
Sean:
What happened with your GSR motor??
Steve
Old Jan 5, 2003 | 08:05 PM
hybridsol's Avatar
Default Re: B20VTEC Ready for boost- Hondata MAP? (stevecockrill)
Spun a connecting rod bearing. Had enough with it. It was burng oil and needed to be re-bored; I tried new rings and a getto hone job. I kind of worked, but I was still going through a quart every 500 mi. Gave it the old boot, and bought a B20B. Swapped on the head, put a Cometic (sp?) 2mm head gasket on and never looked back.
I got the turbo on today , took longer than I expected (8 hrs) . I'm unning the DRAG map from Hondata. It seems pretty close with the WB. I've got it up to about 4 psi,the BOV is kicking in too early. The oil return line leaks too, I'll fix that tomorrow.
Boost is awesome! I can't belive it all works! the engine is so smooth and quiet. Way cool!
Sean
Old Jan 5, 2003 | 08:29 PM
V-SPEC 1's Avatar
I don't think it matter, cause if you see the tube, it's going inside the down pipe anyway recycling the waste.
Old Jan 5, 2003 | 10:13 PM
DefiantGSR's Avatar
Default Re: B20VTEC Ready for boost- Hondata MAP? (boostedb20vtec)
yeah it does matter, its better for flow/backpressure reasons
Old Jan 5, 2003 | 10:24 PM
chameleon's Avatar
Default Re: B20VTEC Ready for boost- Hondata MAP? (DefiantGSR)
phatty turbo stock bottom end
i give it a few months
Future50
Sep 14, 2009 06:30 PM
Dakota
Feb 4, 2009 01:20 PM
ragethemachine86
Jul 15, 2006 03:53 PM
queez
Dec 27, 2003 07:24 AM
9krpm
Aug 15, 2002 11:00 AM
