b20b vs b20z
Old Nov 30, 2001 | 05:40 PM
b18cTurbo's Avatar
Default b20b vs b20z
whats the difference between b20b and b20z?
i know compression is difference
ive eard that oil pump is not the same ?
is the head and the intake the same?
thx
Old Nov 30, 2001 | 07:10 PM
HXMan's Avatar
Default Re: b20b vs b20z (mikvtec)
Different intake manifolds....the b20b has the big tunnel ram. Also, I am not sure but I though I heard something about the b20b or maybe it was the b20z having a knock sensor?
Old Nov 30, 2001 | 07:44 PM
b18bvudoo's Avatar
New User
Default Re: b20b vs b20z (HXMan)
b20b is crv right? whats b20z?
Old Nov 30, 2001 | 08:04 PM
1's Avatar
Default Re: b20b vs b20z (vudoo666)
Both are CRV. The JDM B20B is the same specs as USDM B20Z.
Old Dec 2, 2001 | 08:40 AM
Mr.FBR's Avatar
Default Re: b20b vs b20z (1)
B20b 1997-98
126hp @ 5400 rpm
133 ft-lbs (18.4 Kg-M) @ 4300
8.8:1 CR
Can be visually identified by the high valve cover...
B20z 99-00
146hp @ 6200 rpm
133 ft-lbs (18.4 Kg-M) @ 4500
9.6:1 CR
This one has the knock sensor.
Old Dec 2, 2001 | 10:42 AM
Suprdave's Avatar
Default Re: b20b vs b20z (Mr.FBR)
Can the B20z Knock-Sensor be bypassed by using a Chipped P28 ECU?
Aren't the problem that some people run into are using VTEC ECU's on the B20b without KNock Sensors?
Suprdave
Old Dec 2, 2001 | 12:06 PM
VTC_CiViC's Avatar
Default Re: b20b vs b20z (Suprdave)
Also know that the B20Z uses the same cams as the B18B1.
nightscream
Aug 10, 2012 04:44 PM
B20Panda
Feb 2, 2010 04:29 AM
ninezeroteg
Feb 24, 2009 02:56 PM
star_boi
Jun 9, 2006 01:17 PM
