B20B blockguard complete.
Old Nov 12, 2002 | 10:28 AM
turbopanda's Avatar
Default B20B blockguard complete.
Got a call from my mechanic telling me that he'd finished the blockguard install in my B20B. Here's some pictures here for you guys to look at..
The blockguard is made out of aluminium, 9mm thickness.
Sorry if the pictures are unclear, but there is plastic wrapped around the block.
Old Nov 12, 2002 | 10:33 AM
paulzy's Avatar
Default Re: B20B blockguard complete. (turbopanda)
Nice...musta took a while to make
Old Nov 12, 2002 | 10:37 AM
turbopanda's Avatar
Default Re: B20B blockguard complete. (paul_vang)
He said it took him a good 3 hours to get the right fitment & drill the holes according to the gasket. Originally he was going to cut out the part where the cylinders meet up with eachother, but seeing how all the boosted b20b's here cracked at that point, I told him to just drill a hole around that area, as I wanted the blockguard to make those points strong too. He said the fitment is very tight. I hope it works.
Old Nov 12, 2002 | 11:43 AM
Charlie Moua's Avatar
loosk nice. Not the best fit and craftsmanship but it should serve it's purpose very well. how much are you planing on boosting?
Old Nov 12, 2002 | 11:53 AM
Jeff C's Avatar
Did he hone the cylinders after the install? Does he know for sure that they are perfectly round?
I know somebody that had a blockguard made for his b20 and it apperantly oblonged the cylinders...just a thought.
Old Nov 12, 2002 | 12:00 PM
metal-x's Avatar
Default Re: B20B blockguard complete. (Jeff C)
forgive my ignorance but is using a block guard another method of sleeving a block? how different are the two
Old Nov 12, 2002 | 12:43 PM
rainmanEK's Avatar
big strong guy
Default Re: B20B blockguard complete. (metal-x)
they are not the same!
eric
Old Nov 12, 2002 | 12:48 PM
The Mole's Avatar
Default Re: B20B blockguard complete. (rainmanEK)
ive heard of a lot of over heating problems with these....but from what i read yours was custom mad with water holes lined up with head gasket...all of them?? maybe it will work out good for you!! i hope its all good!!
Old Nov 12, 2002 | 04:56 PM
turbopanda's Avatar
Default Re: B20B blockguard complete. (Silver EG)
I've used a blockguard in my B18C, and in my D16Y8 when my Civic used to be turbo, and never ever had any overheating problems. I think its just from improper installations that give the "blockguard" a bad name.
Old Nov 29, 2002 | 12:35 PM
turbopanda's Avatar
Just curious, how much boost do you people think I could push on stock b20b rods/pistons. and with 84 or 84.5mm JE pistons/eagle rods (both with stock sleeves + blockguard as you can see above) - this with be running with a fully built B18C head, and a fully programmable ECU running 95 octane pump gas and 8.2:1 compression ratio..
[Modified by turbopanda, 4:37 AM 11/30/2002]
Old Nov 29, 2002 | 12:43 PM
Speed PHreak's Avatar
I dunno i'd say. Most smart people are wary of those sleeves cracking. I'd say around 14~16 lbs with some good tuning and no detonation.
Old Nov 29, 2002 | 03:17 PM
philo's Avatar
I had problems with my STR blockguard defelcting the top of my sleeve, if i was ever gonna use one again i would weld it in, deck the block then hone the cylinder.
Old Nov 29, 2002 | 04:02 PM
avividmemory's Avatar
Default Re: B20B blockguard complete. (philo)
is it better for a blockguard to sit at the top like that, or rest farther down? most ive seen sit about 3/4-1" down
Old Dec 1, 2002 | 10:42 AM
turbopanda's Avatar
Default Re: B20B blockguard complete. (SpoolinLS)
the other blockguard I used to run in my old D16Y8 turbo was installed in the same manner as the pics in this post - never had any problems with the sleeves ever since I had the blockguard installed.
usdmEHboy
Sep 16, 2012 03:43 PM
B-money
Dec 25, 2004 02:56 PM
JDMB16DA6
Jul 27, 2004 07:57 PM
DC2R714
Jul 14, 2003 04:53 AM
