Is the b20b block good for boost with b16 head??
Old Jul 23, 2008 | 02:15 PM
maddcrx's Avatar
Default Is the b20b block good for boost with b16 head??
I was wondering if the b20b block with a b16 head is good to hold 450whp!!
I have already 84mm JE pistons and ls eagle rods!!
I was planning to build a ls/vtec, but my pistons and rods came for a b20.
A friend told me that the cylinder walls are narrower than the ls or b18c and
do not hold so much HP. Is that true!! Any help??
Old Jul 23, 2008 | 02:36 PM
da.nizzle's Avatar
Default Re: Is the b20b block good for boost with b16 head?? (maddcrx)
Search will yield you faster results young jedi
Old Jul 23, 2008 | 02:50 PM
lakai_19's Avatar
i got a b20b stock block with a gsr head. check sig for power and i beat on it pritty good and havnt had any problems. alot say they are bad for boost but its all in the tune
Old Jul 23, 2008 | 03:16 PM
hotrod99's Avatar
Default Re: (lakai_19)
i dont know that i would use the b20 if your looking for 450whp the sleeves are thinner than the rest of the b-series motors...unless you have a badass tuner but still i think thats pushing it.
Old Jul 23, 2008 | 05:06 PM
maddcrx's Avatar
Default Re: (hotrod99)
I'ved checked the thickness on the sleeves on a friends b20b and to me it seems the same thickness than the other b-series.
Old Jul 23, 2008 | 05:23 PM
morgan@synapse motorsport's Avatar
Default Re: (maddcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maddcrx &raquo;</TD></TR><TR><TD CLASS="quote">I'ved checked the thickness on the sleeves on a friends b20b and to me it seems the same thickness than the other b-series.</TD></TR></TABLE>
how about the thickness between the cylinders?
its not just about the thickness of the sleeves more so how the b20 blocks are made.
a piston and rods 81.5mm b18 would be a much better choice for your 450whp goals.
dfinch88
Aug 5, 2010 12:46 PM
Riceeater702
Jan 25, 2010 10:29 AM
cuzzfolk99
Jan 20, 2009 03:32 PM
sickb16b
Jul 25, 2005 07:08 AM
Acuracy
Sep 4, 2002 12:17 PM
