B20 w/ boost fuel management????
Old Oct 6, 2004 | 05:26 AM
black98gsr-t's Avatar
Default B20 w/ boost fuel management????
what type of fuel management are people using when they have the famous sleeve failure. also is detenation the only thing to possibly cause that. I'm thinking of running my greddy kit on my current setup B20B with gsr head all stock. i figure 5-7 psi should be ok as long as it does not detenate. I' read the many b20 posts about people cracking sleeves and what not but there are those that manage to run this with no problems.
Old Oct 6, 2004 | 06:42 AM
Islandspeed's Avatar
Default Re: B20 w/ boost fuel management???? (black98gsr-t)
I have a buddy that cracked his sleeves on 11 PSI. He was using forged pistons and rods and running a Hondata S200B. The simple fact is that these block shouldn't be boosted over 8 PSI without sleeves. It's kind of an "all or nothing" thing. You should be OK as long as you stay below 8 PSI.
Old Oct 6, 2004 | 01:45 PM
Default Re: B20 w/ boost fuel management???? (Islandspeed)
thanks for the info. i figure its a gamble.... any one else with input ???
Old Oct 6, 2004 | 01:48 PM
Smokinsax's Avatar
The Boot
talk to TurboPanda...
he had a b20 boosted ~18psi with a block guard and stock sleeves...it can be done.
Old Oct 6, 2004 | 06:29 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (Smokinsax)
Yeah B20turboic boosts his B20 to 15psi daily with Zdyne.... stock block...
Blaze
Old Oct 9, 2004 | 06:40 AM
B-Hatchie's Avatar
Default Re: (Blaze45)
psi doesnt mean anything its the size of the turbo. a t25 wont make the same power as a t4 at the same psi. so depending how much power you make should be looked at first.
Old Oct 9, 2004 | 09:00 AM
Blaze45's Avatar
Brrraaaap!
Default Re: (B-Hatchie)
I believe hes running a t3/t4 that flows quite a few more CFMs then a t-25....
DelSlow_JDM
Oct 2, 2009 09:26 PM
del_slow420
Jun 29, 2007 06:30 PM
Top Ramen
Apr 22, 2005 05:45 PM
PTR1
May 4, 2004 07:07 PM
B20 BEAST
Apr 19, 2003 11:37 AM
