B20 Vtec Turbo
Old Jan 24, 2005 | 07:19 PM
Tofu94's Avatar
Default B20 Vtec Turbo
Hey my auto teacher picked me up a complete b20 block as a favor and i want to go b20 vtec turbo,and i want to know everything that i will need for a swap,into a 92 civic 4dr ,and i mean everything,i got a eclipse GST fuel pump to help,and i have my VAFC that just all of a sudden died,and i need a new one,anyway i need to know everything,maybe where to go to get it,all engine builders and fanatics this is your time to have fun...give me what you got.
Old Jan 24, 2005 | 09:05 PM
Tofu94's Avatar
Default Re: B20 Vtec Turbo (Tofu94)
bump
Old Jan 24, 2005 | 09:14 PM
PrettyLude's Avatar
what do you want to do with it, na or fi?
Old Jan 24, 2005 | 09:19 PM
Tofu94's Avatar
Default Re: (PrettyLude)
what you mean
Old Jan 24, 2005 | 09:32 PM
Tofu94's Avatar
Default Re: (Tofu94)
sorry,too many beers, fi,turbo and **** alreayd ordered,just need other info,like swap,what i need etc etc and what i should run,im not going for fully built maybe stock bottom with gsr head,or is the LS head good to boost with?
Modified by Tofu94 at 11:00 PM 1/24/2005
Old Jan 24, 2005 | 09:36 PM
Makdaddynuge's Avatar
best thing to invest in is good fuel management
Old Jan 24, 2005 | 10:02 PM
Tofu94's Avatar
Default Re: (Makdaddynuge)
come on im asking the pros on honda tech,what mounts will i need etc,best parts to run for this build,come on people
Old Jan 24, 2005 | 10:31 PM
hasport mounts, full-race turbo kit, talk to earl to build the block
Old Jan 24, 2005 | 11:04 PM
The Specialist's Avatar
Build your block or at least get it sleeved.
Old Jan 25, 2005 | 03:11 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (racer_x_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racer_x_eg &raquo;</TD></TR><TR><TD CLASS="quote">Build your block or at least get it sleeved.</TD></TR></TABLE>
yes. i've always had the understanding that B20 sleeves are weaker due to it being a bigger bore and thinner cylinder walls.
Old Jan 25, 2005 | 12:21 PM
Tofu94's Avatar
Default Re: (AzntaggeR)
whats better to boost with LS or GSR head,and what will be the difference,and also how muc you think it will be to sleeve the b20?
Old Jan 25, 2005 | 12:33 PM
beerbongskickass's Avatar
GSR head is defintely better, the cams are better and the head flows really well. The LS head is the worst head known to mankind, the head flows like *** and the cams are worthless. It's going to cost you more to sleeve the b20 because they have a funky sleeve design that is different than other b-series motors (this also makes them weak and not great for boosting). You should look for a good LS block if your going turbo, you can run the stock sleeves with a b18 just fine. Do some searching and you will find a lot of people with cracked B20 sleeves.
Old Jan 25, 2005 | 01:55 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (beerbongskickass)
i'd go with a b16 head because it flows more air and will lower your compression a bit more over a gsr head.
Old Jan 25, 2005 | 01:56 PM
The Destroyer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">GSR head is defintely better, the cams are better and the head flows really well. The LS head is the worst head known to mankind, the head flows like *** and the cams are worthless. It's going to cost you more to sleeve the b20 because they have a funky sleeve design that is different than other b-series motors (this also makes them weak and not great for boosting). You should look for a good LS block if your going turbo, you can run the stock sleeves with a b18 just fine. Do some searching and you will find a lot of people with cracked B20 sleeves.</TD></TR></TABLE>
Im so close to turboing the B20 Beer, and it will blow one day haha. I have a Spare B18 im gonna reinforce (stock sleeves) so who knows.
Old Jan 25, 2005 | 05:59 PM
Tofu94's Avatar
Default Re: (Vtaaak y0)
i shouldnt have to sleeve,im not going to boost that high,also stock gsr head,and b20 block,what psi should i stay below? and will someone answer my question,what will i need to put this in my 92 civic ,like the shift linkage i should use or mounts.
Old Jan 25, 2005 | 07:04 PM
Tofu94's Avatar
bump
Old Jan 27, 2005 | 11:57 AM
Tofu94's Avatar
Default pistons
well i got the b20 block from my auto teacher,but someone took out the rods,pistons and maincaps,therefore i need them if anyone knows anyone that is selling stock b20 pistons,rods and caps let me know plz. i also need the oil pan,ty
yUNgDRAGER510
26
Feb 26, 2014 09:34 AM
Genocide-kary
Jan 18, 2009 07:05 PM
Battle Cat
Apr 13, 2005 08:00 AM
Brian_92GSR
Jan 24, 2002 12:07 AM
