B20 vtec thicker head gasket
My head gasket is already thicker (.056) I have a thicker one because I'm at 11.8:1 with a supercharger and if I run a stock one I will be at 12.8 which I can't tune safely with 91. So IDE like to find a company other than cometic that makes thicker head gaskets because my cometic one blew within 4000 miles.
I honestly dont believe that Cometic makes shity head gaskets. Ive used them without issue. But if you want to try something else a company called SCE makes copper head gaskets.
I'm working on a b20 vtec turbo build and I had a question on what might be my issue everything is in and now I started it up and there are two codes on it P0112 (Iat) sensor 1 circuit low and also a P1259 can anyone help me on these codes I've tried mostly everything I could already plz.....need help thank.......
My old B20 did this and it wasnt the HG.
I had a small crack in the sleeve and would only overheat when i got up in the RPMs in boost. It was so small i could barely find it.. So check everything closely.
I also use permetex copper gasket sealant on my HG's
