B20/VTEC at 4psi... for now?
Motor runs REAL good. Limited by BOV at 4psi right now. Scared to go higer, don't want to throw a rod or blow it up. Setup:
B20B w/ GSR vtec head/GSR cams/Stage 1 port
STOCK BOTTOM END
2mm Head gasket = 9.0 CR
440 cc injectors
Hondata stage 4b w/ wide band
F-max T3/T4 turbo w/ Tail WG and IC
I can run like this for a while till I get eagle rods/pistons (prob april). Any suggestions? the WG spring is 9psi. Should I gat a 6 psi spring? I have more than enough power to run auto-x right now.
Suggestions PLEASE
STOCK BOTTOM END
440 cc injectors
Suggestions PLEASE
Your rods should be fine, I'd be more worried about the rod BOLTS. I had a crvtec that i revved to 9k all the time, bone stock except for ARP rod bolts. Running a nice 5-7 psi would yield some good power with your setup.
Yea, that's the kind of thin I'm not sure about. The head is good to 10K with all the work I've done, but I've got the rev limiter set at 7K, just to be safe.
Thanks for the reply.
my god you shitting me ? Rev a bone stock b20 to 9k? with no block gridle? ARP rod bolts be good, but its not recommend for stock redline rev like 8000rpm. But after that I suggest you get it for cheap insurance.
goodluck CRVTEC + T3T4 = OWNZ
Yeah the b20 I had is still running low 13s daily driven in someone elses car. They arent all that weak.
Thanks very much for the replies. I won't go past 7K, but I feel better about uping the boost a little (6-7psi). That BOV is annoying at full throttle! I'll post pics on the "show me your **** so I can steal it"post
Sean
Sean
This is on the same set up as yours
well over 12 psi. and drove it home(about 60 miles one way).
pictures courtesy of flip1199
[Modified by accordking, 12:05 AM 1/17/2003]
How long has it been together??? Doesn't matter, it won't be much longer.
actually, this is my friends car and it has been running for atleast 2 years...and still running strong...
A few thing then. Why would you have to run WELL OVER 12 psi to run 11's on a B20/VTEC??? Is he running stock sleeves???? If he is, how many other people have been so lucky???
Don't tell this guy it's O.K. to go more than 10psi on stock b20 sleeves. If he cracks his sleeves are any of you guys going to help him pay for the repair????
With the pleathora of guys who've run WELL over 10psi on B16/18, hell even D16's.. why are you so certain the B20 can't hold it? Sounds to me like YOU had a bad experience with one and it scared you or something. It's all in the tune, if Karl can push as much as he did on a stock B18, I'm sure 10+psi is fine for a B20...tuned!
We have a b16a running 14psi daily with pistons. B20 sleeves are thinner.
Also, I should have added that hybridsol is running a number of things that my friend in the picture above not running like, Hondata, thicker headgasket etc.
FUCATYPR, you are correct about the thinner walls on a B20. But proper tuning and maybe a more reasonable amount of boost, let's say 8-10, hybridsol's set up would be ok. Granted, that the B20 r/s ratio isn't the greatest, high revs would also have to be monitored as well.
[Modified by accordking, 10:37 PM 1/17/2003]
the del sol is running a basic CRVTEC, B20B and b16 head, no pistons, no sleeves, no management (like hondate, f.a.s.t, etc)...and a drag 2 kit...
look at the hypersport crew...i know atleast one of them was just running stock sleeves...(cause the cheap...haha..j/p) they know how to tune it...
and sorry i can't afford to help ppl pay for their motor repair's, sheit...i can barely pay for gas at this point...haha
peace
peace
STOCK BOTTOM END
440 cc injectors
Suggestions PLEASE
STOCK BOTTOM END
440 cc injectors
Suggestions PLEASE
The wg is limiting the boost not the bov and the noise at full throttle is the wg opening to dump excess exaust pressure
I don't agree with the above post, the boost gauge reads 5psi, then the BOV opens.. it's very distinct. Besides, why would the waste gate limit boost to 5 psi with a 9# spring?
Anyway, I'll be tuning it alot more in the coming days, I'll post updated as I go, not too many, and I'll include pics too.
BTW I'm running the stock MAP w/hondata so I really can't go above 11 psi anyway.
Thanks again,
Sean
EK FLY
Feb 7, 2007 10:43 PM
altoid
Mar 2, 2003 07:02 PM
