b20 sleeve
Old Jan 27, 2005 | 12:10 PM
Tofu94's Avatar
Default b20 sleeve
i heard i should sleeve my b20 block before boosting,but i don think ill have to if i keep it under 10psi,but can someone post a pic or 2 of a sleeved bloack and explain what to do and where? my first big swap so im asking the people on H-T for some help
Old Jan 27, 2005 | 04:01 PM
Blaze45's Avatar
Brrraaaap!
Default Re: b20 sleeve (Tofu94)
First off, you should search. I do extensive searchs before I post anything, or If I do post something, its unique and usually hasnt been covered. This topic has been coverd ALOT. What I will tell you is, yes, B20 sleeves are weaker then most other Honda blocks. But if your just going to run 10psi on fair size turbo (IE t3/t4) then you should be fine on stock sleeves with good tunning. It depends so much on that. Any other questions, PM me
Blaze
Old Jan 27, 2005 | 05:22 PM
The Destroyer's Avatar
Default Re: b20 sleeve (Blaze45)
B20 sleeves suck.
Del Sol
Mar 3, 2013 12:39 PM
blackeg
Aug 9, 2008 03:06 PM
prjctwhteg
Oct 21, 2006 01:53 PM
NACvicSi
Aug 17, 2006 07:18 PM
-KangaRod-
Jun 24, 2004 02:29 PM
