B20- Calling out engine goro's-Need HELP
Old Sep 2, 2008 | 04:58 PM
blakkvtec's Avatar
Default B20- Calling out engine goro's-Need HELP
So- I got a pair of JE 13.1 pistons(84mm). Wondering If I can use these pistons with Eagle B16 rods in a B20B. Reasoning behind this is to boost the engine and have a decent comp. ratio for it. I just got on Zealautowerks.com and the #'s look like this...
Static Comp Ratio
10.05: 1
Effective Comp Ratio
9.78: 1
Displacement
1972.87 cc
Piston-to-Deck Height
0.103
Rod / Stroke Ratio
1.51
I think everything should be ok, But need some opinions.
HELP
Thanks
Old Sep 2, 2008 | 05:36 PM
ninesecrx's Avatar
Default Re: B20- Calling out engine goro's-Need HELP (blakkvtec)
So you want to run rods made for a 77mm stroke on a 89mm stroke crank?
Old Sep 2, 2008 | 07:04 PM
pwrofdrm's Avatar
Default Re: B20- Calling out engine goro's-Need HELP (ninesecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">So you want to run rods made for a 77mm stroke on a 89mm stroke crank? </TD></TR></TABLE>
Yeah...not going to work
Deetz
Jun 5, 2017 07:01 PM
1990_integra_DA9
Aug 29, 2007 08:14 PM
CW96
Jan 7, 2007 04:04 PM
frostyrb
Dec 11, 2006 05:51 PM
hispanic panic
Acura TL, RL & ZDX
Dec 17, 2003 02:45 PM
