B18C1 vs B18B
Old Feb 28, 2006 | 01:41 PM
Simmerman's Avatar
Default B18C1 vs B18B
I currently am trying to get a project car. I am building a motor and then buying the car. I have a rev hard stage 2 turbo kit. I am planning on making more boost than it can handle. Im trying to trade that kit for a motor. I was offered a B18C1 (GSR) for trade. The mods are 6 puck clutch, lightened flywheel, skunk2 chipped ecu, engine harness, jumper harness, aem cam gears, stage 2 crower cams, aem pulleys, aem short ram intake, aem fuel rail, itr valve cover, shift linkage, and GSR axles. The motor has approx 70,000 miles on it I was told. I am going to build the expletive out of any motor that I get. But would a GSR be good to build and boost or just go with my plan and get a B18B because of the lower compression? Let me know what you would do and whats mods would you do to the motor? thanks
Old Feb 28, 2006 | 02:25 PM
Simmerman's Avatar
Anybody?
Old Feb 28, 2006 | 02:29 PM
ghostskinner's Avatar
Default Re: (Spike101)
b18c all the way
Old Feb 28, 2006 | 02:51 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: (ghostskinner)
from a guy that already has LS turbo, i decided to pay the extra to have vtec. im currently on a GSR build, it rele comes down to deciding whether you want vtec or not. both motors have potential, so you cant rele go wrong with either. the LS will definately be cheaper but the ability to rev higher and have vtec, determines if you want a GSR turbo.
Old Feb 28, 2006 | 03:03 PM
Simmerman's Avatar
What would you suggest between the 2 you had? with the GSR you could drop it higher?
Old Feb 28, 2006 | 03:16 PM
BLKTeg94's Avatar
You said your going to be building it right? Why not do like the B18B block with a B16 head? Get the longer stroke block and the lower compression vtec head and get the best or both worlds!! The B18C1 trade sounds dope tho I'd do that over the B18B motor anyday.
Old Feb 28, 2006 | 03:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spike101 &raquo;</TD></TR><TR><TD CLASS="quote">What would you suggest between the 2 you had? with the GSR you could drop it higher?</TD></TR></TABLE>
well a stock LS block revs up to 7200 when a GSR can handle almost up to 8100 stock. the ability to rev higher is a big plus for boost and vtec engaged while revving that high convinced me even more to go GSR turbo.
Old Feb 28, 2006 | 03:26 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
i'd keep the turbo kit, get a ls block and build it, slap a nice b16a head on it , get you a girdle for the LS block...i know someone sells em..then you can safely rev higher
Old Feb 28, 2006 | 03:27 PM
Default Re: (BLKTeg94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKTeg94 &raquo;</TD></TR><TR><TD CLASS="quote">You said your going to be building it right? Why not do like the B18B block with a B16 head? Get the longer stroke block and the lower compression vtec head and get the best or both worlds!! The B18C1 trade sounds dope tho I'd do that over the B18B motor anyday.</TD></TR></TABLE>
im not a big fan on LS-V Turbo. the thought has actually crossed my mind a lot but the ability to get a GSR short block at the price of an LS short block, i couldnt pass up the GSR block. Another consideration is that this set-up will be dropped into my daily driver so reliability is a big concern. the extra money to spend on a dependable LS-V conversion is not worth it to me so i decided GSR turbo is the way to go
i loved the torque that my LS turbo has given me but again, im sacrificing torque for VTEC...
vroooooooomBBBBAAAAAAAAAHHHHHH phSSSST !!!!
Old Feb 28, 2006 | 03:33 PM
BLKTeg94's Avatar
Why do you say an LS/Vtec wouldn't be reliable? In the fact that it'll probably be a safer motor to be running boost on due to the fast that LS sleeves are known to be a little strong? When it comes down to reliability tho, it's in the tune.
Old Feb 28, 2006 | 03:35 PM
Simmerman's Avatar
lol. Any numbers for both set-ups?
Old Feb 28, 2006 | 03:37 PM
Simmerman's Avatar
remeber... sleeves really dont matter. im rebuilding the whole thing. trying to figure out what is better?
BLKTeg94's Avatar
Stock GSR block, stock gsr head, DRAG III kit I got 312 hp on 12psi with 91 pump gas.
Old Feb 28, 2006 | 03:38 PM
BLKTeg94's Avatar
are you sleeving then?
Old Feb 28, 2006 | 03:39 PM
Simmerman's Avatar
thats included in a fully built motor.
Old Feb 28, 2006 | 03:50 PM
BLKTeg94's Avatar
dude... definately B18B with a B16 vtec head!!! There's nothing to break! If you build right that motor will handle easy 800 hp!!! There's nothing to worry about. get ya some Crower or eagle rods, piston of your choice, polish the crank, balance the motor, Supertech valvetrain, gsr cams. that's as reliable as it gets. You'll be good to rev to 10,000 rpm if you wanted to. I'm building pretty much the same thing right now. The only difference in the LS block and the GSR block is the long stroke to make for more torque, and the lower compression in the head. Other then that, once you build, everything is the same... The stock B16 flows a little better the the GSR, if your doing port and polish that won't really matter either so. I would buy stuff based on what you want for hp?
Old Feb 28, 2006 | 04:07 PM
Simmerman's Avatar
HP, but I also seen like some low HP make some good track times. Like 350 can run mid 11's. Anybody have some numbers with there set-ups? or times?
Old Feb 28, 2006 | 04:13 PM
BLKTeg94's Avatar
got a friend Mia with a stock gsr, stock internals, FullRace turbo kit make 405 on 10 psi uncorrected, ran a 11.5 at 108mph after hitting the brakes in a full interior GSR
Old Feb 28, 2006 | 04:44 PM
Simmerman's Avatar
WHAT? Serious?
Old Feb 28, 2006 | 04:49 PM
civic nation's Avatar
its all about vtec why have a honda without vtec it makes no sense its just aint right
Old Feb 28, 2006 | 05:13 PM
Simmerman's Avatar
Not necissarlly. LS have alot of TQ but no vtec.
Old Feb 28, 2006 | 05:24 PM
Alchemist's Avatar
GSR will make more power and has more potential.
Old Feb 28, 2006 | 05:30 PM
Simmerman's Avatar
Do you have any reason why?
Old Feb 28, 2006 | 05:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKTeg94 &raquo;</TD></TR><TR><TD CLASS="quote">Why do you say an LS/Vtec wouldn't be reliable? In the fact that it'll probably be a safer motor to be running boost on due to the fast that LS sleeves are known to be a little strong? When it comes down to reliability tho, it's in the tune.</TD></TR></TABLE>
LS-V will always have a bigger reputation of not being as reliable as a straight GSR. theres a lot to take into consideration when building a reliable LS-V. LS-V turbo will definately make more power i know that but i rather stick with the original design of the honda motor supplying sufficient amount of oil to the head correctly rather than through an oil line. There will also be a required amount of oil pressure needed to supply the head thru that oil line and still supply a sufficient amount of oil to the turbo. You also have to worry about a PERFECT seal from the oil duct in the block that originally supplies oil to a non-vtec head, and perfect seal in the head to avoid leaking in the gasket.
im not against LSV Turbo at all, ive also considered it myself but for my daily driver, LSV turbo wasnt considered a dependable daily driver. for LSV Turbo, everything has to be built correctly the first time and for higher boost on a LSV, more building is required.
Old Feb 28, 2006 | 05:56 PM
Simmerman's Avatar
This wont be my daily, BTW. You do have a good point.
