B18C1 bottom end!
Old Oct 30, 2001 | 12:08 PM
InfamousRS's Avatar
Default B18C1 bottom end!
http://www.thepartstrader.com/single...1&adnum=200264
I found this at http://www.thepartstrader.com
thik its worth the $500?
If I did buy it I would have it resleeved, use a b16a2 head, and build it for boost.
Old Oct 30, 2001 | 12:09 PM
Rob03Pro5's Avatar
Default Re: B18C1 bottom end! (BLK94RS)
i dont think it's that good of a deal if you need to resleeve it.
Old Oct 30, 2001 | 12:17 PM
InfamousRS's Avatar
Default Re: B18C1 bottom end! (Rob92SC)
What about this one, $150 aint too bad I don't think!
http://www.thepartstrader.com/single...1&adnum=212631
Old Oct 30, 2001 | 12:20 PM
Rob03Pro5's Avatar
not that bad.. get a pic first.. and ask for as much detail as possible! Dont want a block that cannot be resleeved.
Old Oct 30, 2001 | 12:26 PM
InfamousRS's Avatar
what could be wrong with the block that it could not be resleeved, what should I ask about? Also what sleeves are best? Darton, Benson, Golden Eagle?
Old Oct 30, 2001 | 12:29 PM
InfamousRS's Avatar
What compression ration pistons would be best to use if I were to use a b16a2 head? Im planning on running lots of boost!!!!!
Old Oct 30, 2001 | 06:53 PM
earl's Avatar
A spun main bearing would make the block useless. Also missing main bearing caps.
Old Oct 30, 2001 | 09:13 PM
InfamousRS's Avatar
Default Re: B18C1 bottom end! (earl)
is there anyway to tell by looking at a pic if there is a spun main bearing?
jorge59la
Jun 1, 2008 02:08 PM
gsrhatch530
Mar 12, 2004 10:43 PM
spoolin342
Feb 13, 2002 01:02 AM
b18cTurbo
Dec 11, 2001 03:40 PM
