... b18c1 bare block
Old Nov 19, 2002 | 12:41 PM
1.8T_EG's Avatar
Default ... b18c1 bare block
... what is the average price of a b18c1 bare block?... lemme know... thanks...
Old Nov 19, 2002 | 12:49 PM
b18bturbo's Avatar
Default Re: ... b18c1 bare block (1.8T_EG)
bare block with main caps are aroudn 500-700 with crank you looking for around 700-900
Old Nov 19, 2002 | 02:06 PM
1.8T_EG's Avatar
Default Re: ... b18c1 bare block (b18bturbo)
... main caps?... what are these?... got pics?... thanks...
Old Nov 20, 2002 | 09:32 AM
1.8T_EG's Avatar
Old Nov 20, 2002 | 09:35 AM
b18bturbo's Avatar
you dont know what a main cap is... hmm its the caps that hold the crank in place the main caps.. Its where your main bearing go.
Old Nov 20, 2002 | 03:16 PM
earl's Avatar
No offense but, if you don't know what main caps are, you really shouldn't be looking to buy a block. You will probably get screwed on the deal
Old Nov 20, 2002 | 04:10 PM
APEX i GSR's Avatar
contact Rated R if you are looking for a block
he has a bare Golden Eagle B18C block for sale
with all of the internals for sale also including crank
Old Nov 20, 2002 | 04:37 PM
2K_TEG's Avatar
Default Re: ... b18c1 bare block (APEX i GSR)
If you buy just a bare block, you are going to spend a ton of money on all the OEM parts you need if you do not have another block to swap them from.
oil pan, oil pickup, windage tray, crank pulley, timing belt gear, tensioner, plastic covers all add up quick...unless you have those things I would suggest looking for a complete motor.
Old Nov 21, 2002 | 05:32 AM
1.8T_EG's Avatar
... do you know what the bore is?... also, do you know how much he wants for it?... and which 'rated r'... because there are 3 in the member list... ((guessing it is the one with 2000+ posts, but i wanna make sure))... thanks...
Old Nov 21, 2002 | 03:10 PM
APEX i GSR's Avatar
the bore is 81.25mm
you can call him at 770-968-5252 Baranco Acura his nmae is TJ Toreno
good guy who ships stuff quick
Old Nov 22, 2002 | 06:28 PM
2K_TEG's Avatar
the bore is 81.25mm
I think he sold that block to Len (iloveracing) also at baranco acura. I may be wrong though.
JDM90Sleeper
Jan 17, 2008 09:36 PM
x91crxsix
Jul 21, 2006 08:59 AM
AIRIC
Feb 10, 2006 10:54 AM
Bamex
Apr 8, 2004 08:06 PM
b18bturbo
Jul 14, 2002 04:22 PM
