b18c +s2s2 + nitrous ok?
Old Jun 19, 2006 | 11:01 AM
importracer3's Avatar
Default b18c +s2s2 + nitrous ok?
I may buy a 96 civic with a GSR swap. It has a password jdm carbon fiber intake, full 2.5 inch straight through exhaust, p28 ecu chipped, skunk2 valve springs and retainers, port and polished, and some suspension work.
My question: Can I get sunk2 stage 2 cams, AND a wet nitrous kit as long as I have it tuned with neptune of crome or something? How much do you think I could use? I would want the car to be reliable... and I know not to use nitrous too much.
Or would it be best to save up for forged pistons, rods and maybe skunk2 valves just to top it off? I guess that would depend on how much I injected.
So then also I guess what would be safe with s2s2 cams, and stock bottom end? What would be safe with built bottom end? If I were to build it what compression ratio would be ideal?
Thanks
Old Jun 19, 2006 | 12:34 PM
ham's Avatar
ham
Default Re: b18c +s2s2 + nitrous ok? (importracer3)
i think the s2s2 cams bring the max power to high for a stock shortblock. you will get the urge to rev above 10k with those babies. if you use a wet nitrous kit you can tune with just with the jets but proper timing curve adjustments with some sort of management would be better and safer.
Old Jun 19, 2006 | 01:08 PM
ok so skunk2 stage 2 cams, wet nitrous kit for more low-mid range power since I would be running stock bottom end for awhile and wouldn't be able to rev to 10k rpms and then tuning with crome on a p28 ecu. Sound good?
Old Jun 19, 2006 | 02:02 PM
bump
Old Jun 19, 2006 | 02:50 PM
ham's Avatar
ham
Default Re: (importracer3)
you dont really want to use nitrous for low-mid power.
Old Jun 19, 2006 | 04:48 PM
Ok so s2s2 cams, tune with crome, be patient until I can build my bottom end with high compression pistons and forged rods? I think that may be the plan .
Old Jun 19, 2006 | 06:17 PM
ham's Avatar
ham
stage 1 cams until you build your motor
no... that will work good.
Old Jun 19, 2006 | 08:32 PM
OR built high compression b20 bottom end *evil grin*
oianarchy
Dec 11, 2006 07:09 AM
Squirtin EGsr
Jan 17, 2006 06:25 AM
methodz55
Mar 9, 2005 05:36 PM
rustycivic
Aug 28, 2003 07:57 AM
Midwestrider
Mar 21, 2002 11:55 PM
