B18c with hytech manifold
haha, It's so fast, the clips for the side of the windshield got ripped off by the wind
BTW, that's a SICK setup. So sleeperish. No front mount
anyone else notice this thread is really old?
it has a front mount, but its a water cooler for the air to water intercooler. looks the same as a front mount intercooler.
this car made around 590whp on 22psi i belive back in september.
autowerks gets my approval, they are the only ones beside myself and a body shop that have ever worked my car
Straight up SLEEPER...How does it run on the streets considering you have an air-to-water IC instead of the normal air-to-air FMIC? Nice setup by the way!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo »</TD></TR><TR><TD CLASS="quote">Straight up SLEEPER...How does it run on the streets considering you have an air-to-water IC instead of the normal air-to-air FMIC? Nice setup by the way!!!
A/W IC's run fine on the street with a big heat exchanger.
</TD></TR></TABLE>A/W IC's run fine on the street with a big heat exchanger.
http://www.hytechexhaust.com/
You are better off calling John @ Hy-Tech (949) 581-2181
2 things you should know...
It will cost ALOT
It will take a LONG time
John has alot of projects going on all the time. From OEM work to Formula Fords.
But his quality of workmanship is about as good as it gets and well worth the wait.
It will cost ALOT
KiNGDEE206
Engine Management and Tuning
Jul 8, 2018 07:31 PM
